> Dist for a 2.7 RS
Red-Beard
post Feb 11 2004, 12:53 PM
"Ya canna change the laws of Physics"
As I started final assembly of my 2.7 RS spec motor (S cams, RS P&C,2.7 crank), I found the mechanical advance dist cap is cracked. It's a Marelli and it was setup for a 2.0T. I have a 2.7 vac adv dist, a Bosch. Will this work? Am I better off with something else?
James
JmuRiz
post Feb 12 2004, 09:50 PM
Didn't know if you did any of them fancy 'engineoutofcar' dynos or anything. Good luck though...i'm just a little jealous.
(IMG:style_emoticons/default/burnout.gif)
Red-Beard   Dist for a 2.7 RS   Feb 11 2004, 12:53 PM
!   Nope....Marrelli is a differernt animal....you wou...   Feb 11 2004, 03:36 PM
Red-Beard   I was just informed the 2.7 bosch will not fit my ...   Feb 11 2004, 03:49 PM
!   There have been converted motors,,,seen them, neve...   Feb 11 2004, 03:54 PM
GLENN914-6   Red Beard what case is your 2.7 rs built on? The 2...   Feb 11 2004, 04:07 PM
Brad Roberts   For a very large lump sum I can steal the one from...   Feb 11 2004, 07:51 PM
J P Stein   There is a Bosch replacement for the Marrelli. I...   Feb 11 2004, 08:17 PM
Red-Beard   Engine was built on my 914/6 case, so call it a 2....   Feb 11 2004, 10:19 PM
meursault   Yes, a 2.7 distributor will not fit a 2.0 case. Yo...   Feb 12 2004, 12:57 AM
Red-Beard   Point away! Actually, I'm going to have t...   Feb 12 2004, 07:31 AM
!   Did you try Glenn? Or better yet, Scheider Autoha...   Feb 12 2004, 08:35 AM
Red-Beard   Not yet. But I'll call Glenn and the rest toda...   Feb 12 2004, 08:43 AM
Justin Fischer   There's a Marelli from a 71 911 T 2.2 ending o...   Feb 12 2004, 01:42 PM
JmuRiz   James, How did you get your 2.0 to become a 2.7? ...   Feb 12 2004, 01:58 PM
Red-Beard   Dyno runs? Sheesh, I'm still working at gettin...   Feb 12 2004, 07:52 PM
JmuRiz   Didn't know if you did any of them fancy ...   Feb 12 2004, 09:50 PM
jkeyzer   Is a 2.0 case even a 5R?   Feb 12 2004, 11:46 PM
Red-Beard   Uh - no.... It's built on my original case. I...   Feb 12 2004, 11:59 PM
ArtechnikA
- Lo-Fi Version Time is now: 31st October 2024 - 09:27 PM
