Dist for a 2.7 RS |
Dist for a 2.7 RS |
Red-Beard |
Feb 11 2004, 12:53 PM
"Ya canna change the laws of Physics" Group: Benefactors Posts: 1,124 Joined: 11-February 03 From: Houston, TX Member No.: 288 Region Association: None |
As I started final assembly of my 2.7 RS spec motor (S cams, RS P&C,2.7 crank), I found the mechanical advance dist cap is cracked. It's a Marelli and it was setup for a 2.0T. I have a 2.7 vac adv dist, a Bosch. Will this work? Am I better off with something else?
James |
Red-Beard |
Feb 12 2004, 11:59 PM
Uh - no....
It's built on my original case. I had the case extensively modified to take the larger cylinders, installed piston squirters for the Nikasil Cylinders, The crank&rods were changed to a 2.4, case savers installed at _every_ tapped hole, S cams, ported cylinder heads, standard S valves, RS pistons and cylinders, ported the intake manifolds to match the cylinder intakes. I expect at least 210 hp. James (IMG:style_emoticons/default/MDB2.gif) |
Lo-Fi Version | Time is now: 31st October 2024 - 09:31 PM |
