> Continuing Work on My 914 EZ30R Twin Turbo Conversion, 1/31/12, nothing new just started working on the car again pic will follow
TwinTurbo914
post Jun 13 2008, 11:21 AM
Well its still subaru powered, but ive made the swap over to the EZ30R H6 3.0 Subaru motor Read on
Hey Guys I finally got some time and the motivation to start working on my project car again. I started it a few years ago but, got side tracked on a few other project but I have decided to come back to it and finish it.
I all started 3-4 years ago when i got my first subaru wrx and decided i loved the power plant and thought what better way to add a lot of power to a light car. So i started with getting a twin turbo ej20 subaru engine from japan. I also bought the kennedy engineering adapter kit. I worked on the car for awhile, then got busy working on other project and kind of abanoned it. But no im back working on it about 5 nights a week.
But lucky I did take a break from it cause i decided to make to big changes to the car( since i can afford them now. Im going to use the stock subaru trans, with a bremar 2wd kit. Im going to use big brakes all the way around, i have some big reds for the front, and im goin to do the rear also. Car is getting a full cage, and all longs and suspension pickups are going to be plated and reinforced. And i decided to swap over to the single turbo set up for simplicity of tuning, and more maximum power output. ( im eventually swaping in a built 2.5 STI engine)
So i thought id start a thread to show my progress on my car, and will glady answer any questions along the way if anyone is looking to do a similar swap. Seems like the subaru conversion has gained a lot of popularity since i started my project quiet awhile ago.
Started working on it about one and a half weeks ago, and so far got my interior stripped out, and gonna pick up my material for my cage next week. I got my transmission mounts fabricated, and my engine mount fabricated, and now im working on reinforcing the shock tower and such where my engine mount attaches to. Here's some picks of my progress hope you all enjoy
(IMG:http://www.914world.com/bbs2/uploads_offsite/img.photobucket.com-752-1269359998.1.jpg)
Here the engine sitting in the car
(IMG:http://www.914world.com/bbs2/uploads_offsite/img.photobucket.com-752-1269359999.2.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/img.photobucket.com-752-1269360000.3.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/img.photobucket.com-752-1269360000.4.jpg)
Transmission mounts, there not done yet still gotta cap all the ends on them and powder coat them and such
(IMG:http://www.914world.com/bbs2/uploads_offsite/img.photobucket.com-752-1269360001.5.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/img.photobucket.com-752-1269360001.6.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/img.photobucket.com-752-1269360002.7.jpg)My exhasut header and big uppipe
(IMG:http://www.914world.com/bbs2/uploads_offsite/img.photobucket.com-752-1269360002.8.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/img.photobucket.com-752-1269360004.9.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/img.photobucket.com-752-1269360004.10.jpg)
Engine mount ill show some pics of it installed later its out right now as im tig welding it up right now
(IMG:http://www.914world.com/bbs2/uploads_offsite/img.photobucket.com-752-1269360005.11.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/img.photobucket.com-752-1269360005.12.jpg)
My stripped out interior, getting ready to prep it to plate the longs and start my cage
(IMG:http://www.914world.com/bbs2/uploads_offsite/img.photobucket.com-752-1269360006.13.jpg)
Numbchux
post Sep 4 2009, 12:19 AM
very cool! what do you plan to run for management? stock ECU won't work in a porsche due to immobilizer issues, so you'll be running a standalone of some sort. I know Hydra can run the EZ30DR, but the AVCS and AVLS control is open loop. the new Link can control them all with closed-loop mapping, but that setup is extremely expensive.
I bought an EZ30DR shortblock about a month ago.....haven't decided what to do with it. putting it in a 914 has crossed my mind....
(IMG:http://i26.photobucket.com/albums/c108/Numbchux/DSCF0707Medium.jpg)
TwinTurbo914
post Sep 4 2009, 10:59 AM
QUOTE(Numbchux @ Sep 3 2009, 10:19 PM) *
You posted your engine as ez30dr, there is actually two different engines the 01-04 engine which has no variable valve lift or variable cam timing, and its called the ez30d they also only have one exhaust port per head. The engine im using is the ez30r which has the cam lift and valve timing, and three exhaust ports on each head. The ez30r was made from 05-07, then they changed to the ez36r which isnt any good for performance because of the offset connecting rods.
Both of the ez30's are awsome engines with tons of performance potential, outfront motorsports builds them for dune buggys and has made over 1100 HP with a stock block with a closed deck, and a stock crankshaft. Cant wait to get mine going.
Im looking into the link its not that much more expensive then the hydra. But i have quite awhile before i have to worry about Engine management.
But have been making progress on the car just nothing to exciting to show any pics of
Numbchux
post Sep 4 2009, 09:54 PM
QUOTE(TwinTurbo914 @ Sep 4 2009, 11:59 AM) *
common mistake, the actual engine code is EZ30DR. the '05+ one with AVCS and AVLS is the DR. the motor I have came out of an '05 Tribeca. the 3.6 is a DR as well, but it has AVCS on both intake and exhaust cams. too bad about those rods though.
anyway, sweet project. I have worked with a few Links on various swaps, and have an older one (v4 Link 1) that I plan to use on my supercharged EJ22e (which might find it's way into a 914....). I would highly recommend going that route.
budman, are you a Link dealer? I need a ComLink for my ECU....
budman5201
post Sep 13 2009, 12:24 PM
QUOTE(Numbchux @ Sep 4 2009, 08:54 PM) *
Yep I have a comlink. Can you take a picture of your input port so i can make sure its the correct one for your application?
TwinTurbo914   Continuing Work on My 914 EZ30R Twin Turbo Conversion   Jun 13 2008, 11:21 AM
jd74914   Very cool. Keep us posted on your prgress. :)   Jun 15 2008, 08:02 PM
scotty914   that engine mount design looks like i have seen it...   Jun 15 2008, 09:18 PM
rick 918-S   that engine mount design looks like i have seen i...   Jun 15 2008, 10:48 PM
TwinTurbo914   Yah Im going to sleeve and cap everything when im ...   Jun 16 2008, 01:15 PM
rick 918-S   :popcorn: :headbanger:   Jun 16 2008, 09:16 PM
kylehall21   Any twin turbo parts that you want to get rid of? ...   Jun 27 2008, 10:16 PM
TwinTurbo914   Any twin turbo parts that you want to get rid of?...   Jul 7 2008, 05:51 PM
TwinTurbo914   Well i have not given any updates lately as things...   Jan 8 2009, 10:48 AM
ONTHEGRIND   Well i have not given any updates lately as thing...   Jan 8 2009, 11:33 AM
EVILGENIUS13   Well i have not given any updates lately as thin...   Jan 9 2009, 03:56 AM
TwinTurbo914   Well I worked on cleaning up in the shop a little ...   Jan 12 2009, 10:51 AM
TwinTurbo914   Well i have Been working away at the car when ever...   Jan 13 2009, 11:10 AM
quadracerx   [b]DUDE....your like liv'in the dream...LOL :D...   Jan 13 2009, 09:34 PM
charliew   Put the suby in that Izetta? isetta?   Jan 13 2009, 09:46 PM
turnaround89   Nice work. Very cool, wish my hell hole looked li...   Jan 13 2009, 10:02 PM
ChrisNPDrider   Yes, that trunk section braces between shock tower...   Jan 13 2009, 10:13 PM
TwinTurbo914   [b]DUDE....your like liv'in the dream...LOL :...   Jan 14 2009, 10:33 AM
TwinTurbo914   Nice work. Very cool, wish my hell hole looked l...   Jan 14 2009, 10:44 AM
charliew   Do you know about the suby to bus adapters from po...   Jan 14 2009, 12:36 PM
TwinTurbo914   Do you know about the suby to bus adapters from p...   Jan 14 2009, 01:33 PM
TwinTurbo914   Im making good progress on the interior reinforcem...   Jan 22 2009, 06:40 PM
jd74914   Im making good progress on the interior reinforce...   Jan 22 2009, 10:08 PM
cymaster007   What do you have planned for your radiator/cooling...   Jan 22 2009, 08:43 PM
TwinTurbo914   What do you have planned for your radiator/coolin...   Jan 23 2009, 10:40 AM
TwinTurbo914   Well Im still plugging away at the car, the inter...   Jan 29 2009, 10:38 AM
TwinTurbo914   Hey everyone sorry for no updates, but I haven...   Mar 3 2009, 02:58 PM
MZM   Happy for you that you have a growing business the...   Apr 5 2009, 11:56 PM
Zaney   I vote for an EZ36 too! I believe they are ro...   Apr 6 2009, 10:08 AM
TwinTurbo914   From the research i've done the ez36 has offse...   Apr 6 2009, 01:21 PM
charliew   If I where you I would check on the axle adapters.   Apr 7 2009, 12:25 PM
TwinTurbo914   Finally got to work on the car a little bit this w...   May 4 2009, 01:18 PM
TwinTurbo914   Sorry for being so slow on updating on the progres...   Jun 29 2009, 11:16 AM
TwinTurbo914   Well i have been making some progress on the car, ...   Jul 13 2009, 03:04 PM
gopack   soOOOO very cool! keep it up and you may insp...   Jul 13 2009, 03:21 PM
RiqueMar   Haha, weird. We are both 914 owners. We both live ...   Jul 13 2009, 05:15 PM
TwinTurbo914   Both of our car are orange also LOL Haha, weird....   Jul 13 2009, 05:34 PM
ghuff   This should turn out to be a lot of fun. Sheetmeta...   Jul 13 2009, 06:10 PM
TwinTurbo914   Well here as promised, a little late the never are...   Jul 14 2009, 10:31 AM
TwinTurbo914   Well im slowly making progress, here a few pics fr...   Aug 11 2009, 11:29 AM
charliew   Boy you trust the tranny crossmember way more than...   Aug 13 2009, 12:16 AM
TwinTurbo914   Boy you trust the tranny crossmember way more tha...   Aug 17 2009, 01:13 PM
Numbchux   very cool! what do you plan to run for managem...   Sep 4 2009, 12:19 AM
TwinTurbo914   very cool! what do you plan to run for manage...   Sep 4 2009, 10:59 AM
Numbchux   [quote name='Numbchux' post='1210763' date='Sep 3...   Sep 4 2009, 09:54 PM
budman5201   [quote name='Numbchux' post='1210763' date='Sep ...   Sep 13 2009, 12:24 PM
Numbchux   Yep I have a comlink. Can you take a picture of y...   Sep 13 2009, 03:11 PM
TwinTurbo914   Well not to much new going on still plugging away ...   Sep 28 2009, 01:46 PM
budman5201   very cool! what do you plan to run for manage...   Sep 4 2009, 02:49 PM
TwinTurbo914   NOPE I can get you a Link for $1100 shipped t...   Sep 4 2009, 03:07 PM
budman5201   NOPE I can get you a Link for $1100 shipped ...   Sep 4 2009, 05:25 PM
DBCooper   I think the base G4 box only has four ignition dri...   Sep 4 2009, 03:26 PM
TwinTurbo914   Haven't done a ton of research on the G4 but I...   Sep 4 2009, 04:06 PM
charliew   I will follow this my son and I are looking at sta...   Sep 12 2009, 10:21 AM
budman5201   I will follow this my son and I are looking at st...   Mar 26 2010, 12:30 PM
TwinTurbo914   I will follow this my son and I are looking at s...   Mar 29 2010, 10:02 AM
jd74914   I will follow this my son and I are looking at s...   Mar 29 2010, 03:24 PM
TwinTurbo914   Well started on the Rollcage this last weekend and...   Oct 14 2009, 10:57 AM
TwinTurbo914   Well Great news today, I finally got my engine. ...   Dec 7 2009, 11:24 AM
TwinTurbo914   Well Finally Got the engine out of my truck yester...   Dec 9 2009, 10:45 AM
strawman   Sweet, a big block Suby! I'm kinda surpri...   Dec 10 2009, 12:13 AM
charliew   It might just be a different motormount. Did you t...   Dec 10 2009, 10:08 AM
TwinTurbo914   It might just be a different motormount. Did you ...   Dec 10 2009, 10:23 AM
charliew   I'm sure you are using solid mounts to avoid m...   Dec 10 2009, 11:09 AM
budman5201   Oh hey that shiney header you have on your ej20 lo...   Dec 10 2009, 10:51 PM
TwinTurbo914   Oh hey that shiney header you have on your ej20 l...   Dec 11 2009, 10:36 AM
Heater Guy   Looks good! Keep going. Hope to have mine at ...   Feb 24 2010, 03:38 PM
number6   Looks good! Keep going. Hope to have mine at...   Feb 24 2010, 04:31 PM
quikshft   First post in this forum guys, this is an interest...   Feb 27 2010, 04:10 AM
TwinTurbo914   Still Working on the car, but progress has been ex...   Mar 4 2010, 12:11 PM
quikshft   Still Working on the car, but progress has been e...   Mar 23 2010, 01:55 PM
TwinTurbo914   Well finally found some time to put into the car, ...   Mar 23 2010, 09:52 AM
Zardozz   Now I haven't eaten lunch yet so I might be a ...   Mar 23 2010, 03:50 PM
TwinTurbo914   Now I haven't eaten lunch yet so I might be a...   Mar 23 2010, 04:59 PM
Zardozz   Yah there is 3 bolts on each side that bolt to th...   Mar 23 2010, 06:11 PM
strawman   Great work! Are you solid-mounting the engine/...   Mar 23 2010, 05:11 PM
TwinTurbo914   Great work! Are you solid-mounting the engine...   Mar 23 2010, 07:12 PM
quadracerx   Great work! Are you solid-mounting the engin...   Mar 25 2010, 06:25 PM
TwinTurbo914   What kind of tubing did you use....Mild Steel or...   Mar 26 2010, 09:36 AM
Frost   Man that looks good, that is some nice engine mou...   Mar 25 2010, 04:30 PM
effutuo101   very nice!   Mar 25 2010, 05:43 PM
budman5201   Hey what computer are you using? I just picked up ...   Mar 26 2010, 11:53 AM
budman5201   Does anyone have a already completed map for the E...   Mar 29 2010, 06:28 PM
DBCooper   There's an Australian shop, one of the Link pe...   Mar 29 2010, 09:48 PM
budman5201   There's an Australian shop, one of the Link p...   Mar 29 2010, 11:21 PM
DBCooper   It's Dave at D-Tech, dave@dtechmotorsport.com,...   Mar 30 2010, 09:17 AM
TwinTurbo914   I talked with Link last year at the sema show, an...   Mar 30 2010, 09:29 AM
budman5201   wow, thankyou guys for that info. I looked forever...   Mar 30 2010, 04:11 PM
TwinTurbo914   Not much of an update but, I haven't had much ...   May 12 2010, 12:07 PM
TwinTurbo914   Well Cliff over at Turbo Power in Cameron Park cam...   Jun 3 2010, 03:02 PM
charliew   So you eliminated the wastegate. How does this com...   Jun 4 2010, 08:41 AM
TwinTurbo914   These were not internal gated housings, and these ...   Jun 4 2010, 09:34 AM
charliew   You might want to make the jig a permanent fixture...   Jun 4 2010, 09:38 AM
Zardozz   That's what I call turbo porn... I need a mo...   Jun 4 2010, 06:05 PM
Andyrew   What size turbo's? Vband flange, Nice! I ...   Jun 4 2010, 06:27 PM
TwinTurbo914   I got the turbo's mocked up in the engine bay ...   Jun 7 2010, 09:35 AM
ClayPerrine   Now those are some gutless turbos!!! ...   Jun 7 2010, 11:35 AM
TwinTurbo914   As promised here are some pics of the progress, o...   Jun 8 2010, 09:44 AM
TwinTurbo914   I got a lot of work done on the car this weekend, ...   Jun 14 2010, 09:48 AM
TwinTurbo914   Here's a few pics of all the hot side plumbing...   Jun 21 2010, 06:48 PM
- Lo-Fi Version Time is now: 14th December 2025 - 05:14 AM
