How to make your own Bronze shift bushing. |
rick 918-S |
Sep 13 2009, 05:26 PM
Hey nice rack! -Celette Group: Members Posts: 20,785 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I needed to change my rear shift bushing for my side shift transaxle. The last time I installed my drive assembly I used some shrink tube around the outer surface of the busing to tighten it up in the hole through the shift console. Even though I used the shrink tube it was still loose on the outer surface and even looser on the inside hole. Here's a picture showing the space with a pick tool.
Heres a picture of the band aid repair. And the shrink tube. And the real reason I used the shrink tube. The bushing was cracked. |
rick 918-S |
Sep 13 2009, 05:47 PM
Then I used a small drill bit and drilled two small holes through both bushing flanges and the aluminum console and added a safety wire. The press fit was so tight I didn't need the safety wire. But I added it anyway.
Lo-Fi Version | Time is now: 23rd November 2024 - 07:15 PM |
