Gas tank is back in, Thanks to Dr914 |
PanelBilly |
Sep 17 2009, 09:56 PM
914 Guru Group: Members Posts: 5,824 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
I had the tank in place, but needed to paint the straps that hold it in place. Out it came again. I saw the thread about the new nut Dr had for the gas tank and thought hard about the old seals that I had used. I just couldn't put it togeather with the old seals and take a chance of a fire. Today the new parts arrive and its back togeather again.
Speaking of fires, we had one a month ago, The cloths dryer started smoking and I'm so lucky that my daughter and the grandkids got out of the house because a heat wave flashed through the building and basically destroyed everything. Trust me kids. I've always thought that if the house was on fire, I could run in and get stuff, but if anybody had been in the building when the flash when through the house they would have been fried on the spot. So if you have a fire, get the hell out and stay out. The carpet in this house is MELTED, not from the fire, but the heat wave that flew out from the fire in the laundry room. The flat screen tv on the other side of the house was melted too. Nearly everything was roasted. Here's the laundry room Attached image(s) |
detoxcowboy |
Sep 17 2009, 11:24 PM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
What nut and what seal?? I have had my tank out and replaced and refurbished and have put in new screen and sender unit re-fuelined etc. and have no idea what your talking about.. advise so i can be assured I did not miss something?? also why would you expect fire in the fuel tank area?? What would ignite it?? I smoke while changing the fuel filter, gas needs a hot spark..
kconway |
Sep 17 2009, 11:53 PM
Senior Member Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California |
What nut and what seal?? I have had my tank out and replaced and refurbished and have put in new screen and sender unit re-fuelined etc. and have no idea what your talking about.. advise so i can be assured I did not miss something?? also why would you expect fire in the fuel tank area?? What would ignite it?? I smoke while changing the fuel filter, gas needs a hot spark.. How did you replace the screen without removing that nut holding the screen/tube in on the bottom of the tank? Remove the nut, damage the seal you could have a fuel leak. |
detoxcowboy |
Sep 18 2009, 12:25 AM
What nut and what seal?? I have had my tank out and replaced and refurbished and have put in new screen and sender unit re-fuelined etc. and have no idea what your talking about.. advise so i can be assured I did not miss something?? also why would you expect fire in the fuel tank area?? What would ignite it?? I smoke while changing the fuel filter, gas needs a hot spark.. How did you replace the screen without removing that nut holding the screen/tube in on the bottom of the tank? Remove the nut, damage the seal you could have a fuel leak. the washers (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 09:08 AM |
