ghuff |
This is certainly not what I expected down here. ![]() ![]() ![]() Group: Members Posts: 849 Joined: 21-May 09 From: Bodymore Murderland Member No.: 10,389 Region Association: MidAtlantic Region ![]() |
So I pulled apart my distributor and it was definitely sticking. You could turn it back a few degrees and the grease was dried up and sticky.
When I got it down to the centrifugal weights and springs at the base, one of the plastic spring mounts broke. I am thinking a dab of jb weld over the end to keep the spring from leaving and flying up over it? On the plus side it does not seem to stick at all anymore and goes right back to stop once you twist it. I guess this is why everyone complains about these? What a pain. At least nothing else broke. I doubt the little plastic spring seats are available. Hopefully it will run close to right the spring had to be clamped a little bit to keep it on the shaft.... |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,920 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
AA has new repro distributor plates for about $30. Seem the plates and hardware are starting to fail.
Lo-Fi Version | Time is now: 25th June 2024 - 11:35 PM |
