ghuff |
This is certainly not what I expected down here. ![]() ![]() ![]() Group: Members Posts: 849 Joined: 21-May 09 From: Bodymore Murderland Member No.: 10,389 Region Association: MidAtlantic Region ![]() |
I have yet to find a product this cheap that works this well. 12$ a tube and it is better than the permatex right stuff and VW sealant that is 40$ per tube.
It's RTV but thicker, and you can sculpt with it almost. I used a very light layer of it on my intake pieces. This was after removing the dead paper gasket from the phenolic spacer/intake manifold gasket on my 1.8l L-jet. Snugged down the 13mm nuts on the studs and barely any visible bleed out. It's thick so it will not compress out like RTV unless you torque on it very hard. I guarantee this seals better than any brand new intake manifold gasket. Not original/concourse but I could not see spending 8$ on a new gasket to get another plastic phenolic spacer with paper attached to it that sucks. (IMG:http://www.handa-accessories.com/hondabondlrg.jpg) You could easily do an oilpan gasket out of this, it is much easier to work with than permatex right stuff, which I had used in the past for gasketless sealing. We all know standard RTV sucks and compresses out, does not stick etc. Pick up a tube for 12$ and see for yourself, most honda dealers have it or order it from the internet. If I missed the memo on an equal or better product for this price or cheaper please let me know. Opinions, and your favorite sealants and stuff for these jobs? I want to add, this stuff rules so much the sealant creep effect on compression was so miniscule there is no way it would creep into the intake ports.... like the RTV over the dead greasy/oily paper that was on there before. Also, all surfaces should be super clean. I wire brushed the head surface and held my shop vac next to the brush/ports to suck debris up then vacuumed the intake ports back out as well. |
Sleepin |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,647 Joined: 20-November 07 From: Grand Junction, Co. Member No.: 8,357 Region Association: Rocky Mountains ![]() |
Hondabond is great IMO! I have used it for a lot of unorthodox things!
ghuff |
Hondabond is great IMO! I have used it for a lot of unorthodox things! Hondabond or hondabond HT? I hear this HT stuff is thicker, like a gasket maker vs. a regular RTV viscosity/thickness. I looked up the temp spec and it's like 600 degrees. Doh says it on the tube! I know guys using it on oil drain gaskets of turbo cars that see well over 500 there, and it still does not fail FWIW. Stuff seems to be great and useful all over. I plan on using it to seal my trans cases back together on my VW's and the 914. |
Lo-Fi Version | Time is now: 25th June 2024 - 08:37 PM |
