Bosch distributor parts? Tips on getting the distributor back together, Hey look I broke some 30 year old plastic inside of the distributor. |
ghuff |
Sep 22 2009, 03:14 AM
This is certainly not what I expected down here. Group: Members Posts: 849 Joined: 21-May 09 From: Bodymore Murderland Member No.: 10,389 Region Association: MidAtlantic Region |
So I pulled apart my distributor and it was definitely sticking. You could turn it back a few degrees and the grease was dried up and sticky.
When I got it down to the centrifugal weights and springs at the base, one of the plastic spring mounts broke. I am thinking a dab of jb weld over the end to keep the spring from leaving and flying up over it? On the plus side it does not seem to stick at all anymore and goes right back to stop once you twist it. I guess this is why everyone complains about these? What a pain. At least nothing else broke. I doubt the little plastic spring seats are available. Hopefully it will run close to right the spring had to be clamped a little bit to keep it on the shaft.... |
SLITS |
Sep 22 2009, 01:53 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Your distributor will be a Bosch 0 231 176 048 / VW 021 905 205 AB.
Want one? ... it's sitting on my desk but needs to be cleaned. Oh, the ball bearing is held in place by the little hat and screw you see in the upper right of the housing. (IMG:http://i239.photobucket.com/albums/ff312/professor914/P1010010-1.jpg) A couple of more for your entertainment ... (IMG:http://i239.photobucket.com/albums/ff312/professor914/P1010011-1.jpg) (IMG:http://i239.photobucket.com/albums/ff312/professor914/P1010012-1.jpg) Wow, that second image must have been taken by Sire Ahandie!!! |
Lo-Fi Version | Time is now: 25th June 2024 - 11:35 PM |
