TC 914-8 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 812 Joined: 23-May 08 From: Sequim, WA Member No.: 9,090 Region Association: Pacific Northwest ![]() ![]() |
I haven't been a big fan of the "tuner" exhaust systems as of late. but my existing 2 1/2" pipes looked like pea shooters. So I broke down and picked up 2 - 3 1/2 " resinator tips. They look much better and give the new V-8 a deep droan.
![]() Old 2 1/2 " tips ![]() New 3"+ tips |
charliew |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 ![]() |
If the motor was bored oversize sbc's tend to run hotter the thinner the cylinderwalls get. Also a new motor will be hotter than a broken in motor. You might want to get a stethescope and listen to the stuff you suspect before you start taking things off. Even if the squeel is gone a dry bearing will sound really loud with a stethoscope. Also listen to the top bushing in the dist it can get dry setting, it will usually turn and get the motor out of time when it galls though. If you suspect bearings you can check the oil for residue you know.
TC 914-8 |
If the motor was bored oversize sbc's tend to run hotter the thinner the cylinderwalls get. Also a new motor will be hotter than a broken in motor. You might want to get a stethescope and listen to the stuff you suspect before you start taking things off. Even if the squeel is gone a dry bearing will sound really loud with a stethoscope. Also listen to the top bushing in the dist it can get dry setting, it will usually turn and get the motor out of time when it galls though. If you suspect bearings you can check the oil for residue you know. Yep, I am dreading checking the oil. Oil Press is still strong though, so I am rulling out bearing issues,for now. I did think about Dist. but the noise came from the front of the engine. There was also a crunching noise along with the squeel. At this point, I would be happy to find water pump or Alt problems..... I'll know more later this week. Thanks for the input, T |
Lo-Fi Version | Time is now: 25th June 2024 - 10:31 PM |
