Where is Ground Connection"B" ? |
kenshapiro2002 |
Sep 23 2009, 12:21 PM
Senior Member Group: Members Posts: 1,441 Joined: 23-July 09 From: Bawlmer, MD Member No.: 10,598 Region Association: MidAtlantic Region |
Where is the ground numbered #83 (Ground connection "B") on a 1970 914? It's not the one in the rear trunk, and not the one by each headlight. It's the one that grounds all the dash switches, door switches, fan and heater switch, etc.
kenshapiro2002 |
Sep 24 2009, 06:41 AM
OK...just went out to "play". The turn signals will actually cause the chatter after a few seconds. At first they click normally, and then after 2-3 second the chatter begins. A few weeks ago when the problem first surfaced, it was applying the brakes that started the chatter, and a quick flick of the turn signal would stop it. With some experimenting today, use of the four way flasher will stop the chatter, but it often takes 2-3 pulls. Here's an example...
turn on ignition (not to starter), use turn signal. Sounds normal for a few seconds, then the chatter begins. Pull out 4 way flasher control and chatter gets worse...almost a constant buzz instead of rapid clicking. Use the 4 way switch a few more times, and all quiets down. Question #3. Putting the beast into reverse does not cause the problem. Not sure if my reverse light even works. If that matters I'll close the garage door and see if the light is illuminating. Question #2. When the chatter is happening, no matter which side of fuse#9 I place my analog, ancient, volt meter, the needle heads south! Goes below zero. (IMG:style_emoticons/default/WTF.gif) |
kenshapiro2002 |
Sep 24 2009, 07:01 AM
OK...no question #2 I had the wires reversed! My meter might not be spot on accurate, but I get the same reading on all three (+) poles as well as the (-) pole...a little less than 12 v.
OK...just went out to "play". The turn signals will actually cause the chatter after a few seconds. At first they click normally, and then after 2-3 second the chatter begins. A few weeks ago when the problem first surfaced, it was applying the brakes that started the chatter, and a quick flick of the turn signal would stop it. With some experimenting today, use of the four way flasher will stop the chatter, but it often takes 2-3 pulls. Here's an example... turn on ignition (not to starter), use turn signal. Sounds normal for a few seconds, then the chatter begins. Pull out 4 way flasher control and chatter gets worse...almost a constant buzz instead of rapid clicking. Use the 4 way switch a few more times, and all quiets down. Question #3. Putting the beast into reverse does not cause the problem. Not sure if my reverse light even works. If that matters I'll close the garage door and see if the light is illuminating. Question #2. When the chatter is happening, no matter which side of fuse#9 I place my analog, ancient, volt meter, the needle heads south! Goes below zero. (IMG:style_emoticons/default/WTF.gif) |
Spoke |
Sep 24 2009, 09:23 AM
Jerry Group: Members Posts: 6,994 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
OK...no question #2 I had the wires reversed! My meter might not be spot on accurate, but I get the same reading on all three (+) poles as well as the (-) pole...a little less than 12 v. When you turn things on and off, does the voltage change much? Just checking in case there is resistance at the fuse. Are the fuse contacts and fuse box contacts clean? Emery cloth or fine sandpaper will clean them up nicely. When you say "all three (+) poles", what are you referring to? On fuse #9? |
Lo-Fi Version | Time is now: 26th June 2024 - 04:12 AM |
