bandjoey |
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,929 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region ![]() |
4 Happy shakedown days for the 914 at MUSR! Car on the road for the first time in a year! Serious oil leak! Quart per hour. Oil pooling all over the top of the motor and smoking out the engine lid, not burning oil. Eye after eye looked at what might be the obvious and we all missed this one... (IMG:style_emoticons/default/confused24.gif)
A MISSING CRANK CASE BOLT - RIGHT ON TOP - IN PLAIN SIGHT!. Granted, I missed it for a year. Also, I havn't done a die test (suggested) yet and will still be cleaning the bottom of the motor tomorrow and then go on the search for the leak. I want to fill in the hole, can it be a bolt from Home Depot? Special size? Locktite? What should it be torqued to? What should the other bolts I can get to be torqued to? Are they all the same? (IMG:style_emoticons/default/headbang.gif) Do you think this is enough to let a quart per hour pop out the top of the motor? [color=#000099] Suggests please - especially if you had lots of oil all over the top of the motor. Thanks guys! Bill Attached thumbnail(s) ![]() |
davep |
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,162 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada ![]() ![]() |
I agree, the missing case bolt is the least of your worries. It is a standard 8mm bolt, so readily available. It would certainly help case rigidity, and would be beneficial for the crank and bearings, but I doubt it could cause a leak. Crank, oil cooler seals and the pressure sender are the usual suspects.
Lo-Fi Version | Time is now: 26th June 2024 - 03:47 AM |
