wobbletop |
Member ![]() ![]() Group: Members Posts: 382 Joined: 8-December 06 From: Ontario, Canada Member No.: 7,335 Region Association: Canada ![]() |
Hi,
The plastic cover for my side shifter linkage is not installed. To install it, I need to separate the shift rod from the shift rod end. Separate #27 from #24 in this diagram... (IMG:http://www.pelicanparts.com/914/Parts/Pedals/shift_linkage_side_big.jpg) Any tips? I have the tapered screw out (#23), but the two pieces seem very tightly joined. I have searched, but most refer to the joint close to the firewall. Will I be able to replace the plastic cover with just this joint removed, or will I need to take off the firewall joint as well. Thanks, Walter |
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
You can use heat as well, but make sure the surface is relatively clean so you dont start a class B fire (IMG:style_emoticons/default/wink.gif)
osvolant |
Newbie ![]() Group: Members Posts: 33 Joined: 31-August 09 From: Oak Ridge, TN Member No.: 10,748 Region Association: South East States ![]() |
I am a 914 newbie- have been struggling with the same problem (getting the shift rod head off of the rod). My car is a 76 2.0 and it looks like the rear bushings have never been replaced. The cover is in great shape but found rust on the rod.
Have tried PB blaster, heat, beat, repeat, and small gear puller. No fires yet but have melted the old ball cup bushing! I am trying hard not to bugger up the head and the trans casting. In the meantime I have rebuilt the shifter and replaced the firewall bushing but I am (literally) stuck. I have thought about reconnecting the two shift rods and shifter and using the gear lever to pull/twist on the shift rod. Anybody ever done this? Thanks. (IMG:style_emoticons/default/chair.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 08:19 AM |
