Pat Garvey |
Do I or don't I...........? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,899 Joined: 24-March 06 From: SE PA, near Philly Member No.: 5,765 Region Association: North East States ![]() |
I have ONR chip in my paint - ONE! It's been there since I dropped a screwriver in the 80's. Rest of the paint is perfect.
I'm looking for something that doesn't require a brush, since I am known to be sloppy. Concerned about compatability, since my paint was put on in 1979, and is a poly-razzmataze paint of the era. Clear coated too. Paint was a Glssurit compound. Could look it up, but just wondering. There are "pens" out there, but I don't want them bleeding/bubbling what I have. Suggestions? Pat |
scotty b |
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None ![]() |
Go to the local paint supplier, get a half pint of the correct color for the car, using a toothpick, get just enough on the end to ball up, place the drip on the chip and let it sit till it starts to set up. Do this until the chip is higher than the surrounding paint. Let the car sit for a couple days. NOW you can start to wet sand the spot with 1500-2000 grit. Use a hard block so you are just knocking off the top of the buldge, eventually it will sand down level and you can lightly buff it. Won't match exactly, but unless you want to take it in for the whole panel to be shot........ that is your best bet
jonferns |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,081 Joined: 29-March 07 From: New Jersey Member No.: 7,631 Region Association: North East States ![]() ![]() |
NOW you can start to wet sand the spot with 1500-2000 grit. Use a hard block so you are just knocking off the top of the buldge, eventually it will sand down level and you can lightly buff it. I can't see Pat (or myself for that matter) touching his car with any sandpaper (IMG:style_emoticons/default/laugh.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 08:37 AM |
