74 2.0L, Running Very Rich, owner quite confused, need diagnostic help |
drumsticks2112 |
Sep 20 2009, 12:56 PM
Newbie Group: Members Posts: 7 Joined: 29-October 08 From: New London Member No.: 9,704 Region Association: Upper MidWest |
Car fires without a problem, but idles quite rough, and runs very rich, so much so that when the it settles down to normal idles, it floods out. MPS was replaced with a used but tested one recently. When it was last running ( a year ago) it ran a little rich, but nothing like this.
As of now, the CHT is not connected. When it is connected, the RPMs jump up to 4000 and stay there. When the CHT is bypassed with direct grounding of the harness, the results are the same as with the sensor being disconnected. I have no reason to suspect the injectors, FPR, Decel Valve, or the MPS. Any and all advice is welcome. -Todd |
Van914 |
Sep 30 2009, 01:13 PM
Van914 Group: Members Posts: 702 Joined: 5-January 03 From: Cincinnati, Ohio Member No.: 90 Region Association: Upper MidWest |
Did you check the adjustment on the FI Brain. I used to run mine 4-5 clicks from closed. CW to rich CCW to lean.
rjames |
Sep 30 2009, 01:36 PM
I'm made of metal Group: Members Posts: 4,111 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Lo-Fi Version | Time is now: 28th September 2024 - 10:58 AM |
