My '73 2.0 street car fixer upper project, Not a major overhaul, just enough to keep me busy |
URY914 |
May 30 2009, 12:53 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 123,041 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
I bought this car in February 2007 from our former member "Rouser", Roy Galen. It came with another '73 2.0 parts car which was badly rusted and a load of parts. It had a bad wheel bearing which I replaced (both) and I changed the rear springs to #180. It has factory sway bars front and rear so it handles pretty well. I haven't done much else to it beside add gas and oil. The car was not originally red but it was a pretty through job with the trunks/jamb/etc painted as well.
It came with a few rust problems: rear trunk, trunk lid, driver/pass floors, jack plate, and other minor paint bubbles. It also has a IMSA f/g nose on it, but Roy had already collected a nice bumper/cap/valance. The best thing about it is it has been converted to five lug Fuchs and they are real not fakes. The hell hole is not bad at all really. It also has A/C and dual 44 Webers on the otherwise stock 2.0. I've now cleaned out the garage to make room and today I moved it in with my race car (also a '73). The plan of attack will be: -replace rear trunk floor -replace driver's and pass. floors -remove the front end and replace with stock -repair all the rusted areas -remove the rear reflector -paint -drive as if stolen I've built a race car, so lets see if I can work on a street car. I will do my best to keep my sawzall away from it. (IMG:style_emoticons/default/biggrin.gif) It looks pretty good when wet and at the right angle and distance... BTW- that targa bar is raddle can painted not vinyl and the lower chrome trim is 1/4 "chrome" pin striping tape. Attached image(s) |
URY914 |
Oct 3 2009, 07:39 PM
The driver's side sidemarker hole was covered over with a fine patch piece just like the other side...........
Attached image(s) |
Lo-Fi Version | Time is now: 28th September 2024 - 12:59 PM |
