> will 911 window cranks fit my 914?, considering my options...
jk76.914
post Sep 21 2009, 03:13 AM
Does anyone know if the '66-'77 911 window cranks will fit the spline of my '76 window regulator? I'm in the home stretch on my interior assembly, and looking at options.
Thanks!
Jim
jk76.914
post Oct 5 2009, 07:39 PM
UPDATE UPDATE UPDATE!!!!!!
I picked up a pair of the earlier style chrome base type, with the plastic cover. And well, THE SPLINE DIDN'T FIT!!! But the good news is, the screw did!!
So I was able to get it to work. The spline has the correct number of teeth- 12, and the major diameter is correct. It's the minor diameter (the ID over the teeth) that is too small. So I drilled it out. Use a 27/64" drill bit, and drill down to the shoulder at the bottom of the spline. Then use a 7/16" bit and drill about 3/16" down into the spline. Last step- take a tiny triangular file and clean up the burrs covering the splines, and sharpen them while you're at it. Takes a few test fits and more filing, but it'll eventually fit.
I like it. Picture below-
- Lo-Fi Version Time is now: 26th December 2024 - 09:52 PM
