Wiring Question, Switched Hot @ Fuse Panel |
andys |
Oct 10 2009, 04:13 PM
Advanced Member Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None |
I need to run a some relays for my V8 conversion, and need a switched +12 volt source. I'd like to tap into a source off the fuse panel. My question is which fuses are 'on' when ignition is on (switched)? I'm pretty sure fuse #8 is switched, but which others are switched? I'd like to use #8 since it's for fog lights (which I don't have), but I believe it's constant +12 volts (since a relay switches them on). BTW, the wiring is incomplete so I can't simply power up the system and turn the ignition switch to read switched sources.
Thanks, Andys |
zonedoubt |
Oct 10 2009, 09:54 PM
Canadian Member Group: Members Posts: 668 Joined: 14-May 03 From: Vancouver, BC Member No.: 696 Region Association: Canada |
andys |
Oct 11 2009, 11:22 AM
zonedoubt, Thanks for the fuse chart, but I already have that. What I need to know which ones are switched on (hot) only when ignition key is turned on. Andys |
Lo-Fi Version | Time is now: 24th June 2024 - 11:33 PM |
