Need An Oil Breather Suggestion |
kenshapiro2002 |
Oct 10 2009, 06:38 PM
Senior Member Group: Members Posts: 1,443 Joined: 23-July 09 From: Bawlmer, MD Member No.: 10,598 Region Association: MidAtlantic Region |
My oil breather hose just dead ends in my cooling "well". What a decent, affordable (like $50 or less) breather box that I can just vent into the atmosphere of the engine bay, pulling off the oil and not throwing it into my engine?
ejm |
Oct 11 2009, 02:02 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,703 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
I've drilled and tapped the heads with the engine assembled but not installed. You need to be careful when the drill drops thru not to hit the valve spring and to keep chips out of the engine.
kenshapiro2002 |
Oct 11 2009, 02:25 PM
Gint |
Oct 11 2009, 04:21 PM
Mike Ginter Group: Admin Posts: 16,094 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
I've drilled and tapped the heads with the engine assembled but not installed. You need to be careful when the drill drops thru not to hit the valve spring and to keep chips out of the engine. (IMG:style_emoticons/default/agree.gif) BTDT Pull the motor. Pop the valve covers off. Drill the head. Insert tube or thread the hole for pipe thread and screw in a fitting. On mine the hole I drilled ended up being a just a little too large for a true press fit. I used a piece of 7/16 or 1/2" (I can't remember exactly now) stainless steel tube. Mixed up a little JB weld and spread on the tube where it fit into the hole and then formed a very small bead around the tube at the top of the head. Done. I've drilled and tapped the heads with the engine assembled but not installed. You need to be careful when the drill drops thru not to hit the valve spring and to keep chips out of the engine. With the valve covers off and the motor put of the car it's easy to keep crap out of the heads while drilling. But watch that valve spring. (IMG:style_emoticons/default/smile.gif) I had to replace one of those while I was at it because I hit one with the drill bit.Yeah? How does one pull that off? |
Lo-Fi Version | Time is now: 22nd November 2024 - 04:02 PM |
