> Need An Oil Breather Suggestion
kenshapiro2002
post Oct 10 2009, 06:38 PM
My oil breather hose just dead ends in my cooling "well". What a decent, affordable (like $50 or less) breather box that I can just vent into the atmosphere of the engine bay, pulling off the oil and not throwing it into my engine?
pcar9146guy
post Oct 12 2009, 07:41 AM
Even though this is used on a six, it's still a single port tank. Got it at Summit Racing. One inlet, ball valve drain, filter, and mounting provision.
kenshapiro2002   Need An Oil Breather Suggestion   Oct 10 2009, 06:38 PM
Racer Chris   a decent, affordable (like $50 or less) bre...   Oct 10 2009, 08:12 PM
SirAndy   Why spend any money at all? Next time you change ...   Oct 11 2009, 02:50 PM
kenshapiro2002   Looks better than that bean can. :D Why spend...   Oct 11 2009, 04:57 PM
Racer Chris   Looks better than that bean can. :D Looks like...   Oct 11 2009, 06:26 PM
kenshapiro2002   I'm just gonna stick a filtered cigarette on t...   Oct 11 2009, 07:30 PM
tomeric914   Looks better than that bean can. :D The EMPI a...   Oct 12 2009, 02:20 PM
kenshapiro2002   They don't have tech inspectors in my neighbor...   Oct 12 2009, 02:32 PM
stephenaki   a decent, affordable (like $50 or less) br...   Oct 18 2009, 10:56 AM
tat2dphreak   you can get little empi breathers for not much, lo...   Oct 10 2009, 08:47 PM
tat2dphreak   here's the best pic I could find, I have the h...   Oct 10 2009, 08:51 PM
kenshapiro2002   Why would you want to move it to the back wall? By...   Oct 10 2009, 09:30 PM
Racer Chris   Why would you want to move it to the back wall? B...   Oct 10 2009, 11:30 PM
kenshapiro2002   Gotcha...thanks. Guess my engine has no vent tubes...   Oct 11 2009, 07:23 AM
Racer Chris   Gotcha...thanks. Guess my engine has no vent tube...   Oct 11 2009, 09:39 AM
kenshapiro2002   How do I do that while the engien is installed wit...   Oct 11 2009, 11:52 AM
Jeff Hail   Why would you want to move it to the back wall? ...   Nov 15 2009, 02:49 AM
tat2dphreak   my reason for moving it to the back is so I can pu...   Oct 11 2009, 09:36 AM
kenshapiro2002   I have no insulation on my firewall. my reason ...   Oct 11 2009, 11:51 AM
tat2dphreak   you can vent the valve covers with fittings, which...   Oct 11 2009, 01:03 PM
ejm   I've drilled and tapped the heads with the eng...   Oct 11 2009, 02:02 PM
kenshapiro2002   Yeah? How does one pull that off? I've dri...   Oct 11 2009, 02:25 PM
Gint   I've drilled and tapped the heads with the eng...   Oct 11 2009, 04:21 PM
tat2dphreak   I think you'll have to block off some.   Oct 11 2009, 08:27 PM
kenshapiro2002   Chewing gum? Piece of potato? I think you'l...   Oct 11 2009, 08:54 PM
tat2dphreak   sure, use a potato... rest of us would use a rubbe...   Oct 11 2009, 09:09 PM
kenshapiro2002   If I can't find a suitable potato, I was going...   Oct 11 2009, 09:19 PM
kenshapiro2002   Where can I get a few of those? If not, whattaya t...   Oct 18 2009, 09:39 AM
bandjoey   OK I'll ask the dumb question. What's the...   Oct 11 2009, 11:04 PM
tat2dphreak   You probably have a small piece of hose laying aro...   Oct 11 2009, 11:12 PM
McMark   Not a dumb question at all. Technically, you...   Oct 12 2009, 12:04 AM
SirAndy   Not a dumb question at all. Technically, you...   Oct 12 2009, 12:13 AM
tat2dphreak   Double post, damn phone   Oct 12 2009, 07:03 AM
kenshapiro2002   Where...where...? :WTF: [b][color=#CC0000]Doubl...   Oct 12 2009, 07:12 AM
tat2dphreak   Where...where...? :WTF: [b][color=#CC0000]Doub...   Oct 12 2009, 09:22 AM
pcar9146guy   Even though this is used on a six, it's still ...   Oct 12 2009, 07:41 AM
kenshapiro2002   Nice. That's what I had in mind, but ordered a...   Oct 12 2009, 08:21 AM
agentblr   Another dumb question: why did the 75-76 cars not ...   Oct 12 2009, 01:57 PM
rhodyguy   with the empi version you will STILL have to find ...   Oct 13 2009, 10:15 AM
tat2dphreak   you can get those at FLAPS. or the piece of hose :...   Oct 18 2009, 10:07 AM
stephenaki   After reading through the entire thread I am of th...   Oct 18 2009, 11:04 AM
johnnie5   I mounted my breather on the rear wall of my engin...   Oct 18 2009, 12:16 PM
stephenaki   I mounted my breather on the rear wall of my engi...   Oct 18 2009, 01:05 PM
johnnie5   Nice, I like it, where'd you get the breather...   Oct 18 2009, 02:36 PM
bandjoey   Anyone with pictures of drilled out valve covers s...   Oct 18 2009, 12:31 PM
Gint   Anyone with pictures of drilled out valve covers s...   Oct 18 2009, 08:18 PM
jschaible   Why is it important to have 2 vents to the rocker ...   Nov 14 2009, 09:41 PM
Vacca Rabite   Why is it important to have 2 vents to the rocker...   Nov 15 2009, 08:31 AM
ottox914   The CFR system is on the turbo 914, and quite simp...   Nov 15 2009, 08:54 AM
jschaible   The CFR system is on the turbo 914, and quite sim...   Nov 15 2009, 10:17 AM
Racer Chris   ottox914 - how can I access your CFR system post ...   Nov 15 2009, 10:21 AM
SLITS   Heads were not vented on '75-'76 engines f...   Nov 15 2009, 09:05 AM
Racer Chris   5.5.) Vacuum to pull the oil vapors / droplets i...   Nov 15 2009, 10:02 AM
mbjarts   I have the VW "bugpack" and it blows oil...   Nov 22 2009, 09:01 PM
r_towle   I have the VW "bugpack" and it blows oi...   Nov 22 2009, 09:26 PM
mbjarts   Possible. Please post a pic of the setup, maybe ...   Nov 23 2009, 12:42 PM
r_towle   Possible. Please post a pic of the setup, maybe...   Nov 23 2009, 06:58 PM
Kargeek   Cut down fan motor bracket and a VW aftermarket ...   Nov 23 2009, 06:54 PM
r_towle   So, I am about to put the CB Performance one in. A...   Nov 27 2009, 09:28 AM
22 User(s) are reading this topic (22 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 22nd November 2024 - 04:34 PM
