Wiring Question, Switched Hot @ Fuse Panel |
andys |
Oct 10 2009, 04:13 PM
Advanced Member Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None |
I need to run a some relays for my V8 conversion, and need a switched +12 volt source. I'd like to tap into a source off the fuse panel. My question is which fuses are 'on' when ignition is on (switched)? I'm pretty sure fuse #8 is switched, but which others are switched? I'd like to use #8 since it's for fog lights (which I don't have), but I believe it's constant +12 volts (since a relay switches them on). BTW, the wiring is incomplete so I can't simply power up the system and turn the ignition switch to read switched sources.
Thanks, Andys |
andys |
Oct 12 2009, 10:03 AM
Anyone?
Andys |
Lo-Fi Version | Time is now: 26th September 2024 - 11:48 AM |
