Valve Adjustment help needed - Vielen dank!, She's running! Thanks for all the help! |
stephenaki |
Oct 11 2009, 03:37 AM
Can I get this one dad?? Group: Members Posts: 1,183 Joined: 11-August 07 From: Palmetto, FL Member No.: 7,987 Region Association: None |
OK, so I have searched and can't find a thread related to my situation, maybe because people are smarter and more experienced than me. The question is pretty much spelled out in the topic description.
The crank, rods, piston and cylinders are 2.0, the heads are machined 1.7, what measurement do I use for the valve adjustment? 1.7 or 2.0? (IMG:style_emoticons/default/confused24.gif) I am leaning towards 1.7 but would like to get an educated opinion from the group. Help please, I want to re-do the valve adjustment before I mess with anything else. |
stephenaki |
Oct 12 2009, 11:24 AM
OK, so, after fiddling around with trying to find TDC, distributor notch not lined up properly and no mark on the impeller fan, I finally got all the valves adjusted.
Unfortunately, she will turn over BUT, won't start! (IMG:style_emoticons/default/headbang.gif) Now, she started on Saturday, ran rough but started then cut out and I couldn't get her to start again. Maybe I flooded the motor? Before I elicit help on the starting piece let me make sure I got TDC correct. I did some searching on the PP forum for finding TDC as well. Here is one simple question as I know it is true on my MG motors. There are two times that TDC on #1 are reached; intake stroke and exhaust stroke. Is it possible that I found TDC on the exhaust stroke and therefore adjusted the valves incorrectly? If, this is not the case with the 914, then, any suggestions on getting her to start? I am thinking ether to get it going and use any fuel that flooded the motor? If I screwed up what I think is TDC then I guess I'll go back to valve adjustment mode tomorrow! I really wish I married a contortionist!! (IMG:style_emoticons/default/blink.gif) |
SirAndy |
Oct 12 2009, 12:15 PM
Resident German Group: Admin Posts: 41,702 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
distributor notch not lined up properly Make sure your dizzy is not 180 degrees off. The shaft with the notch will fit flipped but your engine will never run right. Ask me how i know ... (IMG:style_emoticons/default/dry.gif) Andy |
stephenaki |
Oct 12 2009, 12:20 PM
distributor notch not lined up properly Make sure your dizzy is not 180 degrees off. The shaft with the notch will fit flipped but your engine will never run right. Ask me how i know ... (IMG:style_emoticons/default/dry.gif) Andy Andy, I read on the PP forum on how to line it up but am a bit leary on what I am doing given the couple of items that could fall into the sump! The notch on my dizzy is oriented left on the drivers side and just about dissects the #1 & 2 spark plugs. I read that is should be facing the drivers left front wheel? I think I noticed a mark that the dizzy rotor pointed to when I had it at what I assumed was TDC. My assumption was the guys at Boxter marked the new location as TDC. |
Lo-Fi Version | Time is now: 24th June 2024 - 07:36 AM |
