andys |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None ![]() ![]() |
I need to run a some relays for my V8 conversion, and need a switched +12 volt source. I'd like to tap into a source off the fuse panel. My question is which fuses are 'on' when ignition is on (switched)? I'm pretty sure fuse #8 is switched, but which others are switched? I'd like to use #8 since it's for fog lights (which I don't have), but I believe it's constant +12 volts (since a relay switches them on). BTW, the wiring is incomplete so I can't simply power up the system and turn the ignition switch to read switched sources.
Thanks, Andys |
andys |
Larry,
So fuse #9 is switched, correct? My choices would therefore be fuse #8 and fuse #9. Cap'n, A 12 volt test light won't do me any good as I can't power up the system until most of the harness mod's are complete. I just figured someone here would know which fuses are switched. Thanks guys, Andys |
Lo-Fi Version | Time is now: 25th June 2024 - 12:21 AM |
