mr1970914 |
I'm new here ... Group: Members Posts: 0 Joined: 24-January 09 From: New York Member No.: 9,969 Region Association: North East States ![]() |
Brand new stereo system for sale. The system includes the following items. All pyle items. $390 obo with free shipping to your door via UPS.
8-Inch Low-Profile Amplified Subwoofer (Single) 8'' Low Profile Subwoofer System Suitable for Under-seat Installations. Max Power: 600 Watt RMS Power: 300 Watt Dimension: 14. 5''(D) x 9.5''(W) x 3''(H) Weight 10.5 Lbs 4'' x 6'' 240 Watt Three-Way Speakers One Pair 4'' x 6'' Three-Way Triaxial Speaker Systems Power Handling: 120 Watts Rms / 240 Watts Max Non-fatiguing Butyl Rubber Surround 1'' High Temperature ASV Voice Coil Standard 4'' X 6'' Size Fits Oem Locations Pyle-View Series 2.5'' TFT Monitor DVD/VCD/MP3/CD-R/CD-RW/USB/AM/FM/ Receiver DVD/VCD/MPEG4/MP3/CD/CD-R/CD-RW Compatible PLL Synthesized Tuning Auto Store / Preset Scan 30 Station Memory (18FM/12AM) AM/FM-MPX 2 Band Radio (USA/Euro) Built In 2.5'' TFT Color Monitor On Screen Display Title, Time, Chapter, Subtitle Angle Treble/Bass/Balance/Fader/Volume Controls Dolby Digital Coaxial Outputs Motorized Slide Down Detachable Front Panel Selectable View Angle Anti-Shock Mechanism ESP Function PAL/NTSC Color System LO/DX ST/MO Selectors Repeat/Intro/Random Clock Function Mute Control RCA Line Out Preset EQ Subwoofer Output A/V Input A/V Output Remote Control Rear Camera Output Parking Video Input USB Conenctor USA/Europe Frequency Switch 320 Watts (4 x 80W) Dimensions: 7.24'' (W) x 2.13'' (H) x 6.69'' (D) 1/2'' 150 Watt Mylar Dome Tri-Mount Tweeter 0.5" Mylar Dome High Density Neodymium Magnet Tri-Mounting System: Flush/Swivel/Surface Ferro Fluid Cooling 12Db Crossover Network Frequency Response: 1.3Khz-22khz Spl: 92db @ 1w/1m Power Handling: 75 Watts RMS/150 Watts Max Includes Custom Mounts, Wires and Installation Hardware Attached image(s) ![]() ![]() ![]() ![]() ![]() |
jsayre914 |
Speed Up !!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region ![]() |
hi friend,
do you have any 12" woofers i cold mount under my seat also, next to the amplifier? there is also a spare tire and tool box under the seat. i just want to make sure it will all fit. thanks again (IMG:style_emoticons/default/biggrin.gif) |
mr1970914 |
hi friend, do you have any 12" woofers i cold mount under my seat also, next to the amplifier? there is also a spare tire and tool box under the seat. i just want to make sure it will all fit. thanks again (IMG:style_emoticons/default/biggrin.gif) I have a ultra slim 12" design that just might work for you. Here are the specs for you. 12'' 1200 Watt Ultra Slim DVC Subwoofer 12'' High Quality Poly Mica Cone Butyl Foam Surround Dual 2.5'' High Temperature Kapton Voice Coil Independently Fused 20 Amp Speaker Terminals 75 Oz Magnet Structure Power Handling: 600Watts RMS/1200 Watts Peak Frequency Response:28 Hz - 2.2K Hz Impedance (Per coil) : 4 Ohm Fs:29.1, Qms:4.08, Qes:0.44, Qts:0.396, Vas (L)102.18 Efficiency: 92 dB Overall Diameter: 12.6'' Mounting Depth: 3.28'' Includes Installation Template Attached image(s) ![]() ![]() ![]() ![]() |
Lo-Fi Version | Time is now: 26th June 2024 - 01:40 AM |
