tabs914 |
Advertise Your Drive... ![]() ![]() Group: Members Posts: 105 Joined: 17-January 05 From: Gresham, Oregon Member No.: 3,456 Region Association: None ![]() |
Hello all... I have been trying to trouble shoot my non-starting 914(just cranks). I figured I would start on the fuel injection system, making sure the ECU is getting the proper signals. Here is what I have checked:
MPS Vacuum: Holds 5 Min. + Main Coil: 56 ohms SPEC: 90 Secondary Coil: 348 ohms SPEC: 350 Injectors: SPEC 3 ohms for all injectors Inj 1: 3 ohms Inj 2: 3 ohms Inj 3: 2 ohms Inj 4: 2 ohms Throttle Position Switch Idle Contact: Spec .5 ohms .68 ohms Head Temp Sensor: SPEC 2k ohms Also it is new... 3k ohms I cleaned the trigger points (I don't know if it was a fluke, but this sparked a stummble for one second, only once) New cap/rotor/points Checked Spark from coil wire (Good) Checked Spark from cap (good) Checked Spark at plug (good) Fuel Pump Primes when key is turned Checked the injectors for pulse (when cranking) Good. New fuel filter and lines (the pump is installed correctly I have checked several times (IMG:style_emoticons/default/smile.gif) The AAR warms up if connected to 12 volt. warm closes and opens when cooled down. (not sure if it should do this if I just turn the ignition on? - doesnt seem to warm up if I do.) New vacuum lines backed up with clamps on all connections I can't check fuel pressure - I don't have a guage nor for compression either. Anyone in Portland, Oregon or Vancouver, Washington I can borrow from? (IMG:style_emoticons/default/smile.gif) Maybe someone in the area that can help me out, would be very cool. I am learning alot, but this has me stumped. I haven't had her on the road yet, but I had this baby running pretty well. I was messing around with the head temp sensor when it died. I thought maybe the wire lead became damaged within the sensor casing? Bought a new sensor with no effect. I have three ECU's and I know two work (no effect) The triggers seemed to sparked a stumble, they look ok... any way to test them? Thank you for your help. (IMG:style_emoticons/default/biggrin.gif) Tab |
underthetire |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California ![]() |
Harbor freight sells a fuel pressure tester. It's usually on sale for 7 bucks or so. Has the barbed fitting and a bunch of other adapters. Good home garage tool. Hell, you can barely make one from hardware store parts for that.
http://www.harborfreight.com/cpi/ctaf/disp...temnumber=92699 Guess it's not on sale this week, it usually is, but here is a coupon for 15%off. http://www.harborfreightusa.com/usa/common...mp;keycode=0000 |
tabs914 |
Harbor freight sells a fuel pressure tester. It's usually on sale for 7 bucks or so. Has the barbed fitting and a bunch of other adapters. Good home garage tool. Hell, you can barely make one from hardware store parts for that. http://www.harborfreight.com/cpi/ctaf/disp...temnumber=92699 Guess it's not on sale this week, it usually is, but here is a coupon for 15%off. http://www.harborfreightusa.com/usa/common...mp;keycode=0000 Thats cool... thank you!!! |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:43 PM |
