missing gears |
missing gears |
svsv |
Oct 17 2009, 08:14 PM
Newbie Group: Members Posts: 8 Joined: 26-September 09 From: NC USA Member No.: 10,851 Region Association: None |
ok here we go 2nd & 4th have dissapeared just replaced ball cup in rear they were there after that and now i can hold it were they should be and feel the syncros grab and pull it in then it is in gear but a normal shift not there at all the shifter is perty sloppy but where have they gone (IMG:style_emoticons/default/confused24.gif)
VaccaRabite |
Oct 17 2009, 11:44 PM
En Garde! Group: Admin Posts: 13,615 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
2nd & 4th have dissapeared. I just replaced the ball cup in the rear. They weren't there after that. Now I can hold it were they should be and feel the syncros grab and pull it in then it is in gear; but a normal shift not there at all. The shifter is pretty sloppy. Where have they gone? (IMG:style_emoticons/default/confused24.gif) New and improved with PUNCTUATION! We want to help, but we need to be able to read what you are asking us about without our eyes crossing too. As to your problem, you likely need to replace more then just the ball cup in the rear. If it was gone, and if your shifter is still sloppy, you need to go ahead and replace *ALL* the bushings and 2 cone screws in the shift linkage. Then you will need to readjust your shifter. Once that is gone, the slop will be removed and you will find 2nd and 4th again. My guess is that its also hard to find reverse, as it is also on the 2/4 plane. (IMG:style_emoticons/default/welcome.png) Zach |
svsv |
Oct 18 2009, 08:11 AM
2nd & 4th have dissapeared. I just replaced the ball cup in the rear. They weren't there after that. Now I can hold it were they should be and feel the syncros grab and pull it in then it is in gear; but a normal shift not there at all. The shifter is pretty sloppy. Where have they gone? (IMG:style_emoticons/default/confused24.gif) New and improved with PUNCTUATION! We want to help, but we need to be able to read what you are asking us about without our eyes crossing too. As to your problem, you likely need to replace more then just the ball cup in the rear. If it was gone, and if your shifter is still sloppy, you need to go ahead and replace *ALL* the bushings and 2 cone screws in the shift linkage. Then you will need to readjust your shifter. Once that is gone, the slop will be removed and you will find 2nd and 4th again. My guess is that its also hard to find reverse, as it is also on the 2/4 plane. (IMG:style_emoticons/default/welcome.png) Zach Thanks that is what I was thinking also. Not that I was hoping for that, but just the same. Once again you guys & gals are most helpful. Thank you again...... |
Lo-Fi Version | Time is now: 21st December 2024 - 10:52 PM |
