drive-ability |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,169 Joined: 18-March 05 From: Orange County, California Member No.: 3,782 ![]() |
I'm replacing my Renegade/Chrysler BB pump, since it locked up last night. I didn't here any noise at all ? The engine does make a bit of noise but you would think there would be some warning. Nope ! Maybe something broke off and jammed up the impeller etc. The pump just locked up and melted the drive belt. My question is I have been running a standard pump and decided to get a high volume unit. My assumption is the quality is better than my last one and with A/C it might perform better moving more water. I guess with more pressure comes it own set of issues. One thought is the belt was too tight, and that's a good bet. I'm not running a Thermostat but am running a minor restriction in the thermostat housing, which I think I should remove.. ? Any one have any input here. (IMG:style_emoticons/default/type.gif) |
drive-ability |
people talk about the speed the water goes through the radiator and how it might be a factor, who knows its sounds reasonable to me, but I am running a double pass radiator and that may effect the concept.?? I did run a thermostat but you need a good bypass system or as I did BEND all the impeller blades flat if you don't wait to rev the engine.... LOL
I did look at a electric pump and passed because I have more trust in the belt driven units. Having said that I am replacing a failed one at this time LOL. I would go there if I was running a 215 just for the reason stated. This might be a good time to set up a by-pass system. I have seen some pictures but don't have a real good Idea yet.. I'll let you know how the higher volume pump works... |
Lo-Fi Version | Time is now: 10th April 2025 - 04:38 PM |
