Small displacement turbo. . ., Beginning to plan my new motor |
aircooledtechguy |
Oct 19 2009, 03:43 PM
The Aircooledtech Guy Group: Members Posts: 1,966 Joined: 8-November 08 From: Anacortes, WA Member No.: 9,730 Region Association: Pacific Northwest |
I love the reliability and drive ability of my completely stock 1.8L. . . However, it's just got no balls and w/ approx 160K on it, it's going through oil about 1 quart every 2-3K (burning, not dripping).
I have a completely stock 1.7L block with which to use as a base that has perfect 371Q heads (that will be rebuilt) as well as a spare set of Q heads. My desire is to remove the 1.8L and keep it as is in storage and build a small displacement turbo motor using MS EFI to run it. The goal is to make a completely street drive able motor that when needed can pump out around 140ish HP and plenty of torque without going too exotic. I'm not looking to get 200+ hp by boosting to the moon so one must think fairly mild turbo application. . . It must be affordable. I've got a perfect TD04 turbo that I plan to use that only has about 10K miles on it. At this time, I'm unsure of the turbine and compressor specs but it's not a large turbo and should spool-up pretty quick and the waste gate is adjustable for tune ability. The car it came off of boosted around 10-12 psi if I recall. Pretty standard. The quandary mainly lies in the basic internals of the motor. I'm planning to use a 66 stroke crank and have it welded and ground w/ type-1 journals and use 5.4" H-beam rods. I want the motor to rev easily to 6K. The bore at this point is unclear though. I could have the stock 90mm cylinders bored to 90.5 or 92 OR use a set of 93s I have and bore those to 94 all using forged VW type-1 "B" spec pistons. All these can be done for effectively the same price however for the 94s I would have to have the heads bored. I'm looking for good head sealing and conventional wisdom says keep it smallish to get the thickest walls possible. What think you folks?? Next is cam choice. . . I've never built a turbo motor so the requirements are new to me here. What lobe center is best for turbo?? Again conventional wisdom leads me to a fairly mild grind since it will be force fed anyway, but I defer to turbo experts on this. For heads, I'm leaning toward a more stock rebuild w/ stock sized S/S valves, HD springs, chromoly retainers and light, Manton push rods. Again having never built a turbo specific motor, I'm open to any and all suggestions. What do you turbo experts suggest?? I'm planning to retain the SSI heater boxes and Sebring 4 into 1 header so that I can retain heat (this is a street car that routinely carries my wife) and plumb the exhaust forward to a turbo outside the engine sheet metal. I plan to run an intercooler either under the car with a ducted dedicated fan, or in the engine compartment. I would prefer to have less "stuff" in the engine compartment and have heat sources away from the cooling air, but I'm pretty flexible at this point. EFI will be the latest MS w/ EDIS ignition. I already have made some turbo end-castings and plan to connect them with a custom "T" and have a late model car TB (around 50-60mm in size). Any suggestions on what car to get said TB?? Well that's enough for now. Any suggestions folks can give would be appreciated. |
VaccaRabite |
Oct 20 2009, 01:52 PM
En Garde! Group: Admin Posts: 13,553 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Will an under the car intercooler get enough air? Won't it be getting all the waste hot air from the engine cooling tin?
zach |
ottox914 |
Oct 20 2009, 04:01 PM
The glory that once was. Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest |
Will an under the car intercooler get enough air? Won't it be getting all the waste hot air from the engine cooling tin? zach There is/was a turbo kit for the MR2 spyder that had a thin, wide intercooler mounted in back below the floorpan of the car, the mfg stated with ducting they had great cooling, equal to, if not better than a front mount. But. The MR2 is water cooled, and has (relatively) cool and smooth airflow from the front of the car to the back. With the cooling air of our motors going top down, and exiting the bottom of the motor, I would expect, but have no numbers to prove this, that a low and rear mounted intercooler, would not be all that efficient. I went with a top mount, ducted puller fan set up, and with the smaller turbo and 10-11 psi, have had no problems with it for auto cross. On a 3-4 hr highway drive, in 90 degree + temps, even with the fan on, it will heat soak and intake temps will rise, but not dangerously, and on the highway I'm not heavy into the boost for an extended period anyway. When the new motor is done, the next evolution of the top mount IC will be ducted again, with dual fans pulling air thru it, with more than double the CFM of the single fan now used. I'm considering a tiny bit of water injection as well, more to "steam clean" the heads and chambers and keep any carbon build up/detonation at a minimum. With the SDS I can program this to come in at any PSI that I would choose, so I could, say, run 15 psi max, and have the WI come in at 12 or 13 psi. Without a built motor, 10-12 psi is a good maximum. At that rate, a well designed water injection system may be enough to do what you need it to, with 93+ gas. Read Maximum Boost by corky bell- he's not so keen on water injection, but it works for the WRC cars, it can work for you. I used it on a focus I boosted to 8psi and it was fine for that purpose, low boost, stock internals. When I cranked the boost up and developed it further, I ditched the WI and went with an air/water system. I'd love to build an auto cross only 914 with a wicked boosted motor- build it a 100 pounds or so under weight, and install a 5 gal or so spare tire fuel cell up front, use that to hold ice water for an air/water intercooler. For short auto cross runs, that would be great, having intake air temps below the ambient air temps, oh could you boost that beast. Drain little water and add another bag of ice for each run... |
Lo-Fi Version | Time is now: 26th September 2024 - 11:56 AM |
