Gigamight |
Member ![]() ![]() Group: Members Posts: 220 Joined: 8-June 09 From: Near Akron, Ohio Member No.: 10,454 Region Association: Middle East ![]() |
So I'm searching for a 911 motor, and I come across an 84 and they want $400 for the motor.. woohoo right? Wellllll, they say someone put a 4 cyl "older vw motor in it". So what would anyone in their right mind put in a 911 that is an older 4 cyl vw motor? And is it possible that it could be worth anything? There is nobody in the place that knows anything about the motor.
tat2dphreak |
stoya, stoya, stoya ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region ![]() ![]() |
define "bolt up"?
any type 4 will bolt up, any 6 up to a 3.2 (I think) will bolt up with a 6 conversion. type 1 could be made to work, but why? other than that you gotta go wasserpumper... which is SO not in the family (IMG:style_emoticons/default/biggrin.gif) want easy bolt on hp? build that 1.8 into something with a Jake kit, or a McMark 2056.. hows that for keeping it in the family (IMG:style_emoticons/default/biggrin.gif) |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
define "bolt up"? any type 4 will bolt up, any 6 up to a 3.2 (I think) will bolt up with a 6 conversion. The clutch and input spline can the problem with early Flat Sixes. Flat Sixes From '72 up, the input splining and diameter was changed for the 915 tranny. They also went from 215 mm clutch to the 225 mm. Kennedy can make a flywheel to bolt up to most anything. You will find finding engine tin, engine mounts and exhaust system to put a Type 4 in a bit difficult as it was only fitted to the 912E. There weren't a whole lot of them made. |
Lo-Fi Version | Time is now: 22nd June 2024 - 07:38 PM |
