Need some experts on engines, someone put a vw motor in a 911, what could it be? |
Gigamight |
Oct 20 2009, 08:45 AM
Member Group: Members Posts: 220 Joined: 8-June 09 From: Near Akron, Ohio Member No.: 10,454 Region Association: Middle East |
So I'm searching for a 911 motor, and I come across an 84 and they want $400 for the motor.. woohoo right? Wellllll, they say someone put a 4 cyl "older vw motor in it". So what would anyone in their right mind put in a 911 that is an older 4 cyl vw motor? And is it possible that it could be worth anything? There is nobody in the place that knows anything about the motor.
tat2dphreak |
Oct 20 2009, 08:50 PM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
define "bolt up"?
any type 4 will bolt up, any 6 up to a 3.2 (I think) will bolt up with a 6 conversion. type 1 could be made to work, but why? other than that you gotta go wasserpumper... which is SO not in the family (IMG:style_emoticons/default/biggrin.gif) want easy bolt on hp? build that 1.8 into something with a Jake kit, or a McMark 2056.. hows that for keeping it in the family (IMG:style_emoticons/default/biggrin.gif) |
SLITS |
Oct 20 2009, 09:06 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
define "bolt up"? any type 4 will bolt up, any 6 up to a 3.2 (I think) will bolt up with a 6 conversion. The clutch and input spline can the problem with early Flat Sixes. Flat Sixes From '72 up, the input splining and diameter was changed for the 915 tranny. They also went from 215 mm clutch to the 225 mm. Kennedy can make a flywheel to bolt up to most anything. You will find finding engine tin, engine mounts and exhaust system to put a Type 4 in a bit difficult as it was only fitted to the 912E. There weren't a whole lot of them made. |
tat2dphreak |
Oct 20 2009, 10:06 PM
define "bolt up"? any type 4 will bolt up, any 6 up to a 3.2 (I think) will bolt up with a 6 conversion. The clutch and input spline can the problem with early Flat Sixes. Flat Sixes From '72 up, the input splining and diameter was changed for the 915 tranny. They also went from 215 mm clutch to the 225 mm. Kennedy can make a flywheel to bolt up to most anything. You will find finding engine tin, engine mounts and exhaust system to put a Type 4 in a bit difficult as it was only fitted to the 912E. There weren't a whole lot of them made. maybe I misunderstood. I was thinking of 914 bolt ups, not the 911. I knew about the flywheel conversion, that's just part of the 914 conversion I wasn't thinking about the 911 with the vw engine. big hp for little money is either the suby or SBC. not in the family. for the 911... I couldn't feel right about anything but a flat 6 in there. for a 914, I've gone back and forth... if you want the most hp for your money, then chebbie. but with all that extra weight and hp, you open up other cans of worms.... 1st the Cvs can't handle it, then the 901 can't, then ??? so, imo, a scoobie is probably a lot more practical to get "enough" hp for your money, without going crazy. as much fun as a 914 with a 396 would be... (IMG:style_emoticons/default/biggrin.gif) but even then, we are talking 225 hp? certainly under 300... and a lot of work for that. figure out your "budget", add 25% and see what you can get and what you have to do for each one... I think you'd be looking at a suby @ 225 with a lot of fabbing, a raby kit at about 185, and he did the hard work for you.. or a cheap, budget 6 conversion where you get absolutely lucky on finding some cheap parts for less hp. the difference with the 6 is upgradability later... something to think about. I love aircooled, personally... I'd like to drive a suby conversion, but I wouldn't make one myself, I don't think. |
Lo-Fi Version | Time is now: 20th June 2024 - 06:07 AM |
