> -6 lower valve cover modifications
Scott S
post Oct 22 2009, 09:58 AM
Small Member
Hi All –
I am starting to button up my 2.7 after getting everything cleaned up. I noticed on the PP site that Wayne had to remove a significant amount of the cooling/structure ridges on the lower 930 valve covers. I was surprised at how much material was removed. Is this a “every 914 is a bit different” type mod, or is it always something that needs to be done? Can I simply use a dremel? I don’t want to warp anything….
Thanks! (IMG:style_emoticons/default/beerchug.gif)
Scott S
Ferg
post Oct 22 2009, 10:17 AM
Do them now while they are off, and yes, quite a bit needs to come off.
Scott Schroeder   -6 lower valve cover modifications   Oct 22 2009, 09:58 AM
J P Stein   It needs to be done to all of em'. A considera...   Oct 22 2009, 10:13 AM
Ferg   Do them now while they are off, and yes, quite a b...   Oct 22 2009, 10:17 AM
Scott Schroeder   Here is the pic Wayne sent me. He said he only had...   Oct 22 2009, 10:27 AM
john rogers   Both sixes (2.2L & 2.7L) we had in my race car...   Oct 22 2009, 10:41 AM
Ferg   I would do both sides, IIRC one side I did slightl...   Oct 22 2009, 10:44 AM
MDG   I did mine like the pic shows; did both too. Take ...   Oct 22 2009, 10:53 AM
Cap'n Krusty   Or you "could" use early 911SC aluminum ...   Oct 22 2009, 11:33 AM
ClayPerrine   The Capt'n is right. But if you already have ...   Oct 22 2009, 12:11 PM
J P Stein   You can use bolts....*IF* you heli-coil the thread...   Oct 22 2009, 07:25 PM
sixnotfour   I like to leave a back bone   Oct 22 2009, 08:02 PM
TROJANMAN   Scott, If you can get away, you should come down ...   Oct 22 2009, 09:12 PM
Ferg   Scott, If you can get away, you should come down...   Oct 22 2009, 09:20 PM
TROJANMAN   Scott, If you can get away, you should come dow...   Oct 22 2009, 10:07 PM
9146986   I've always had 5/16" taken off the entir...   Oct 22 2009, 09:21 PM
J P Stein   I like the helicoil or insert / bolt idea, anyo...   Oct 23 2009, 06:58 AM
Gint   Scott, If you can get away, you should come down ...   Oct 22 2009, 09:22 PM
TROJANMAN   [quote name='Ferg' post='1229342' date='Oct 22 20...   Oct 22 2009, 10:21 PM
Scott Schroeder   Gint, Greg - I will need to see one of your rides...   Oct 23 2009, 11:53 AM
MDG   tranny end gets the grind; you can access the nuts...   Oct 23 2009, 12:35 PM
Cap'n Krusty   tranny end gets the grind; you can access the nut...   Oct 23 2009, 01:47 PM
MDG   tranny end gets the grind; you can access the nu...   Oct 23 2009, 02:13 PM
J P Stein   Yes, Wayne is clearly wrong.....nice pic of the ho...   Oct 23 2009, 12:40 PM
MDG   Scott, sorry for the crap pic - shoved the camera ...   Oct 23 2009, 01:03 PM
Scott Schroeder   :worship: :worship: :worship: :worship: Thank...   Oct 23 2009, 02:22 PM
MDG   Thanks!!! Cheers! Grind slowl...   Oct 23 2009, 03:38 PM
Ferg   Still waiting on those pics of the "new toy...   Oct 23 2009, 02:42 PM
Gint   What new toy? Spill it Scotty. Coming on the d...   Oct 23 2009, 02:54 PM
Scott Schroeder   What new toy? Spill it Scotty. Coming on the ...   Oct 23 2009, 03:40 PM
thesey914   Scott, I have been a fan of your Martini GT for ev...   Oct 23 2009, 04:24 PM
- Lo-Fi Version Time is now: 21st April 2025 - 06:33 AM
