> -6 lower valve cover modifications
Scott S
post Oct 22 2009, 09:58 AM
Small Member
Hi All –
I am starting to button up my 2.7 after getting everything cleaned up. I noticed on the PP site that Wayne had to remove a significant amount of the cooling/structure ridges on the lower 930 valve covers. I was surprised at how much material was removed. Is this a “every 914 is a bit different” type mod, or is it always something that needs to be done? Can I simply use a dremel? I don’t want to warp anything….
Thanks! (IMG:style_emoticons/default/beerchug.gif)
Scott S
MDG
post Oct 22 2009, 10:53 AM
Wolf in wolf's clothing.
I did mine like the pic shows; did both too. Take your time grinding as it cuts fast. Pretty easy mod and unless you want to drop your engine every time you need to remove them, you'd better do it now.
Oh, and zero leaks since I did it.
Scott Schroeder   -6 lower valve cover modifications   Oct 22 2009, 09:58 AM
J P Stein   It needs to be done to all of em'. A considera...   Oct 22 2009, 10:13 AM
Ferg   Do them now while they are off, and yes, quite a b...   Oct 22 2009, 10:17 AM
Scott Schroeder   Here is the pic Wayne sent me. He said he only had...   Oct 22 2009, 10:27 AM
john rogers   Both sixes (2.2L & 2.7L) we had in my race car...   Oct 22 2009, 10:41 AM
Ferg   I would do both sides, IIRC one side I did slightl...   Oct 22 2009, 10:44 AM
MDG   I did mine like the pic shows; did both too. Take ...   Oct 22 2009, 10:53 AM
Cap'n Krusty   Or you "could" use early 911SC aluminum ...   Oct 22 2009, 11:33 AM
ClayPerrine   The Capt'n is right. But if you already have ...   Oct 22 2009, 12:11 PM
J P Stein   You can use bolts....*IF* you heli-coil the thread...   Oct 22 2009, 07:25 PM
sixnotfour   I like to leave a back bone   Oct 22 2009, 08:02 PM
TROJANMAN   Scott, If you can get away, you should come down ...   Oct 22 2009, 09:12 PM
Ferg   Scott, If you can get away, you should come down...   Oct 22 2009, 09:20 PM
TROJANMAN   Scott, If you can get away, you should come dow...   Oct 22 2009, 10:07 PM
9146986   I've always had 5/16" taken off the entir...   Oct 22 2009, 09:21 PM
J P Stein   I like the helicoil or insert / bolt idea, anyo...   Oct 23 2009, 06:58 AM
Gint   Scott, If you can get away, you should come down ...   Oct 22 2009, 09:22 PM
TROJANMAN   [quote name='Ferg' post='1229342' date='Oct 22 20...   Oct 22 2009, 10:21 PM
Scott Schroeder   Gint, Greg - I will need to see one of your rides...   Oct 23 2009, 11:53 AM
MDG   tranny end gets the grind; you can access the nuts...   Oct 23 2009, 12:35 PM
Cap'n Krusty   tranny end gets the grind; you can access the nut...   Oct 23 2009, 01:47 PM
MDG   tranny end gets the grind; you can access the nu...   Oct 23 2009, 02:13 PM
J P Stein   Yes, Wayne is clearly wrong.....nice pic of the ho...   Oct 23 2009, 12:40 PM
MDG   Scott, sorry for the crap pic - shoved the camera ...   Oct 23 2009, 01:03 PM
Scott Schroeder   :worship: :worship: :worship: :worship: Thank...   Oct 23 2009, 02:22 PM
MDG   Thanks!!! Cheers! Grind slowl...   Oct 23 2009, 03:38 PM
Ferg   Still waiting on those pics of the "new toy...   Oct 23 2009, 02:42 PM
Gint   What new toy? Spill it Scotty. Coming on the d...   Oct 23 2009, 02:54 PM
Scott Schroeder   What new toy? Spill it Scotty. Coming on the ...   Oct 23 2009, 03:40 PM
thesey914   Scott, I have been a fan of your Martini GT for ev...   Oct 23 2009, 04:24 PM
- Lo-Fi Version Time is now: 21st April 2025 - 06:34 AM
