> 914 Water pump, Yes a SBC
drive-ability
post Oct 20 2009, 01:51 PM
I'm replacing my Renegade/Chrysler BB pump, since it locked up last night. I didn't here any noise at all ? The engine does make a bit of noise but you would think there would be some warning. Nope ! Maybe something broke off and jammed up the impeller etc. The pump just locked up and melted the drive belt.
My question is I have been running a standard pump and decided to get a high volume unit. My assumption is the quality is better than my last one and with A/C it might perform better moving more water. I guess with more pressure comes it own set of issues. One thought is the belt was too tight, and that's a good bet.
I'm not running a Thermostat but am running a minor restriction in the thermostat housing, which I think I should remove.. ?
Any one have any input here. (IMG:style_emoticons/default/type.gif)
burton73
post Oct 23 2009, 05:32 PM
Senior member, and old dude
I would look to the quality of the machine work of the casting of the water pump body. I just spoke to Rod Simpson on this and said he has had only one pump come back in over 30 years after a guy ran his car without water. If the machining is too close the impeller will get too hot and it can bend and jam up. If is to far away it will not pump right because the clearances are wrong.
In Orange County the thermostat should make no difference in this happening.
I never had this problem with my V8 before 30 years ago
Bob
drive-ability   914 Water pump   Oct 20 2009, 01:51 PM
Bruce Hinds   I had some of the same issues, and found that ther...   Oct 20 2009, 02:59 PM
JRust   Are you going with another belt driven water pump?...   Oct 20 2009, 03:11 PM
drive-ability   people talk about the speed the water goes through...   Oct 20 2009, 03:33 PM
dakotaewing   In regard to electric water pumps, it appears that...   Oct 20 2009, 04:05 PM
drive-ability   I have seen that electric pump and do like the ove...   Oct 20 2009, 04:24 PM
SLITS   The speed of flow thru the radiator greatly effect...   Oct 20 2009, 06:18 PM
drive-ability   The speed of flow thru the radiator greatly effec...   Oct 20 2009, 09:42 PM
burton73   I went over this with Rod Simpson at his shop the ...   Oct 20 2009, 07:38 PM
charliew   It's sorta like when you use a paint spray gun...   Oct 20 2009, 09:54 PM
andys   Meziere makes a real nice looking mechanical (belt...   Oct 21 2009, 02:19 PM
computers4kids   TC just lost his Renegade "chrysler" pum...   Oct 21 2009, 06:20 PM
drive-ability   I just got my new pump from Edelbrock, well it won...   Oct 21 2009, 07:13 PM
SLITS   I don't remember when you started the last thr...   Oct 21 2009, 08:40 PM
computers4kids   The gasket should be a Fel-Pro 11730 Jerry ...   Oct 21 2009, 09:26 PM
SLITS   Here are your answers: 1.) the image I showed hi...   Oct 22 2009, 03:12 PM
Bruce Hinds   Thanks for the Interesting thread on the water pum...   Oct 22 2009, 04:04 PM
SLITS   Renegade tried an electric pump on at least one 91...   Oct 22 2009, 06:20 PM
charliew   While you are studying you might look at the reaso...   Oct 22 2009, 07:02 PM
burton73   I would look to the quality of the machine work of...   Oct 23 2009, 05:32 PM
computers4kids   ouch http://www.914world.com/bbs2/uploads/post-909...   Oct 23 2009, 10:41 PM
drive-ability   ouch http://www.914world.com/bbs2/uploads/post-90...   Oct 24 2009, 12:11 AM
computers4kids   I would have dismissed this whole water pump incid...   Oct 24 2009, 08:42 AM
SLITS   There is nothing to say other than there could hav...   Oct 24 2009, 10:39 AM
drive-ability   I have had some time to drive the car and have fou...   Oct 27 2009, 09:10 PM
SLITS   8 vane moves water slower .... low rpm even slower...   Oct 27 2009, 09:15 PM
drive-ability   8 vane moves water slower .... low rpm even slowe...   Oct 27 2009, 09:49 PM
drive-ability   I have found the 6 vane pumps (Chrysler 440) work ...   Oct 28 2009, 11:02 PM
burton73   I have found the 6 vane pumps (Chrysler 440) work...   Oct 29 2009, 02:06 PM
SLITS   How many do you want? Stamped steel Cast iron. ...   Oct 29 2009, 02:24 PM
drive-ability   How many do you want? Stamped steel Cast iron. ...   Oct 29 2009, 04:47 PM
SLITS   Ok, last shot at this subject. The man I am talki...   Oct 29 2009, 06:22 PM
burton73   Ok, last shot at this subject. The man I am talk...   Oct 30 2009, 08:55 PM
computers4kids   Ok, last shot at this subject. The man I am tal...   Oct 30 2009, 11:01 PM
Bruce Hinds   Sorry for the diversion, but has anyone used an el...   Oct 29 2009, 07:00 PM
drive-ability   :clap: Thank You, I now understand there was allot...   Oct 29 2009, 07:07 PM
svsv   :clap: Thank You, I now understand there was allo...   Oct 29 2009, 09:30 PM
charliew   One thing I remember is that a temp sensor in the ...   Oct 29 2009, 10:28 PM
drive-ability   Was thinking about a smaller pulley, so looking ar...   Nov 8 2009, 10:14 PM
charliew   I'm not sure I follow the idea of a smaller ho...   Nov 9 2009, 10:45 AM
Phoenix-MN   I'm not sure I follow the idea of a smaller h...   Nov 9 2009, 11:09 AM
GS Guy   Pretty sure the "Renegade way" is to use...   Nov 9 2009, 06:45 PM
drive-ability   I'm not sure of anything that's the reason...   Nov 9 2009, 08:14 PM
computers4kids   don't run a thermostat: When I spoke to you ...   Nov 9 2009, 08:23 PM
drive-ability   don't run a thermostat: When I spoke to you...   Nov 9 2009, 10:07 PM
charliew   The quicker a motor gets up to 200f the better it ...   Nov 10 2009, 09:13 AM
drive-ability   I thought I would share to the V8 guys what I ende...   Nov 19 2009, 10:43 PM
computers4kids   Thanks for keeping us informed on your progress. ...   Nov 20 2009, 09:17 AM
- Lo-Fi Version Time is now: 10th April 2025 - 04:39 PM
