DNHunt |
914 Wizard? No way. I got too much to learn. ![]() ![]() ![]() ![]() Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 ![]() |
Got my programmer up and running again so if you want to mess with the code I can burn it for you.
No charge cept you pay postage Dave |
3d914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region ![]() |
Dave,
Did you take a different approach at all when programming the second chip? I also wanted to check with you about the part numbers for the two stock temp sensors you're using. I know there are some slight variations of what people use, but then I could get the specs on the parts you programmed for. I'll then compare to tests on my sensors to make sure they're close to what you have. Do you have new pics on your body work results? Regards, |
Lo-Fi Version | Time is now: 26th June 2024 - 12:48 AM |
