Glass fuel filters- What are your thoughts?, Yea or Ney? |
URY914 |
Oct 23 2009, 02:23 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 121,276 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
These things have been around for a long time. VW guys have been using them forever. Advanages being you can see the junk thru the glass and you can clean and reuse them. They are cheap at about $8.00.
Down side is they are glass and can break. IIRC they are not SCCA legal for this reason. If you use them do you install them in the engine compartment where it is less likely to be hit by a rock and break. But when they do break they allow gas to cover the engine. Or do you mount them up under the engine shelf out of the way so when they break they dump gas on the road? Has anyone ever heard of one breaking? I have one for my street car and don't know if I should install it or get a typical OEM plastic/steel body one from my FLAPS. What say you??? Attached image(s) |
URY914 |
Oct 25 2009, 08:13 PM
I have changed all the rubber hoses, the fuel filter, and added a pressure regulator. Today I completed it all. Drove it and it still backfires thru the left side carb when I'm running steady in 3rd gear at 2500 rpm . Tried adjusting the idle screw all the way in and out on both throats and it nearly died so jets are not clogged.
I need to check to see if they are syn'd properly. |
ME733 |
Oct 26 2009, 11:11 AM
Senior Member Group: Members Posts: 842 Joined: 25-June 08 From: Atlanta Ga. Member No.: 9,209 Region Association: South East States |
I have changed all the rubber hoses, the fuel filter, and added a pressure regulator. Today I completed it all. Drove it and it still backfires thru the left side carb when I'm running steady in 3rd gear at 2500 rpm . Tried adjusting the idle screw all the way in and out on both throats and it nearly died so jets are not clogged. I need to check to see if they are syn'd properly. (IMG:style_emoticons/default/popcorn[1].gif) ..(.assumption the carburators are perfectly adjusted , inc. all linkages) float levels and float needle are perfect and not "hanging up"(or down) . THEN, well maybe....remove carbs and dump out the accumulated WATER., drain, fuel in tank check for WATER.. install NEW fuel filters .AND/ OR...valves need adjusting , broken valve spring, bent valve(s). head needs valve job.etc..Look for the reason the intake charge is reversing during the firing cycle.("BLOWING BACK"). Too early ignition timing can also be a problem.worn or bouncing points.loose wiring , breaker plate or points, in distributor...misreading the T.D.C.... (IMG:style_emoticons/default/popcorn[1].gif) |
Lo-Fi Version | Time is now: 24th June 2024 - 06:56 AM |
