drive-ability |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,169 Joined: 18-March 05 From: Orange County, California Member No.: 3,782 ![]() |
I'm replacing my Renegade/Chrysler BB pump, since it locked up last night. I didn't here any noise at all ? The engine does make a bit of noise but you would think there would be some warning. Nope ! Maybe something broke off and jammed up the impeller etc. The pump just locked up and melted the drive belt. My question is I have been running a standard pump and decided to get a high volume unit. My assumption is the quality is better than my last one and with A/C it might perform better moving more water. I guess with more pressure comes it own set of issues. One thought is the belt was too tight, and that's a good bet. I'm not running a Thermostat but am running a minor restriction in the thermostat housing, which I think I should remove.. ? Any one have any input here. (IMG:style_emoticons/default/type.gif) |
drive-ability |
I have had some time to drive the car and have found this 8 blade pump isn't cooling the engine as well at idle speed. At this point I don't know why, there's a restrictor in the thermostat housing and I will be removing it tomorrow. Lets see if anything changes. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 10th April 2025 - 04:39 PM |
