Newly Discovered Hell Hole Cancer |
kenshapiro2002 |
Oct 28 2009, 10:43 AM
Senior Member Group: Members Posts: 1,441 Joined: 23-July 09 From: Bawlmer, MD Member No.: 10,598 Region Association: MidAtlantic Region |
Well, the hole itself was repaired, but I was just able to excavate as seen below. Surrounding area is ice pick proof. What are the best "fixes" to be done while keeping the car together? It does not extend into the interior either and the side runners are very solid (had been replaced too).
Attached image(s) |
rjames |
Oct 28 2009, 11:43 AM
I'm made of metal Group: Members Posts: 4,002 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Well, the hole itself was repaired, but I was just able to excavate as seen below. Surrounding area is ice pick proof. What are the best "fixes" to be done while keeping the car together? It does not extend into the interior either and the side runners are very solid (had been replaced too). Using a wirewheel or grinder, or whatever you weapon of choice is, take the areas down to bare metal and see what you have left to work with. Then fab replacement bits, weld 'em in and be done with it. Additionally, how was the hell hole repiared? (post a pic or two) I would think that if someone went to the trouble of repairing the hell hole correctly, they would have repaired the spots in your photos as well. |
kenshapiro2002 |
Oct 28 2009, 01:18 PM
The hell hole was patched...not with correct sheet metal but simply cut and welded pieces (like no hole for the drain funnel, etc.) twenty years ago. It's stri=ong buut has some surface rust that I'll take care of
Lo-Fi Version | Time is now: 28th June 2024 - 02:56 PM |
