my front mounted oil cooler, a little different |
rfuerst911sc |
Oct 27 2009, 05:31 PM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
As I'm nearing the point of turning the key after 3 years of work I thought I would share what I did for a front oil cooler. First off it's a 75 chassis that has a 911 3.0 installed. Living in Florida I knew a oil cooler was a must. After looking at what was done in the past by others I decided to go a different route. My criteria was I wanted to be able to use the front trunk as a trunk. This will be a street,AX and DE machine. So based on that I went about laying this out in my head. Once I had a basic plan I started buying parts. First off was a MB oil cooler from a diesel. It's made by Behr and well built. I then came up with my mount which basically is two 1/4-20 by 6 inch long bolts welded to the tub facing forward. The cooler has two hoops that slide over the bolts. I made some stand offs to keep the cooler spaced away from the tub for good air flow. I used -12AN hose to go from the cooler to the rear mounted Mocal thermostat. I wanted to keep the length of the hoses to a minimum so I ran them straight back. Under the tub just off center are two channels in the tub. I glued tie down plates to the tub and zip tied the lines tight to the floor. In the rear is the normal routing to engine,thermostat and oil tank. Yes I know my setup is more vunerable to a front end crash or doing something stupid but 911's have had front mounted coolers for a long time mounted up front and low so it can be done. I will be making some stand off blocks in the trunk just high enough to have a front mounted full size spare and then the carpeted cover. Will barely be noticeable to the common eye. I know this isn't for everyone but I'd thought I'd share now that I have everything installed. I am now fabricating a stock valance to have a cutout/snout around the cooler similiar to a early 911 RS valance. Hopefully the pics will show it off. (IMG:style_emoticons/default/biggrin.gif)
Attached image(s) |
jhadler |
Oct 28 2009, 07:10 PM
Long term tinkerer... Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 |
Still... I love the look, and the best part is that it doesn't cut any big holes...
-Josh2 |
Lo-Fi Version | Time is now: 25th September 2024 - 11:02 PM |
