almost ready to install engine (now with pics), where does the brown wire go?? L-Jet |
jsayre914 |
Oct 29 2009, 10:09 AM
Speed Up !!! Group: Members Posts: 3,199 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
where does the brown wire comming out of the loom right near the aar go? it has a single female spade connector on the end. the lable fell off this wire or i forgot to lable it. i dont see anywhere to connect it (IMG:style_emoticons/default/blink.gif)
i am so close (IMG:style_emoticons/default/piratenanner.gif) |
7275914911 |
Oct 29 2009, 10:21 AM
Hummmm!!! Group: Members Posts: 757 Joined: 7-May 08 From: Mid-South Member No.: 9,028 Region Association: South East States |
IIRC
The LJet has a ground wire connection on case under plenum on passenger side. Seems like there are two ground wires that go here. I also had a single ground wire that went to the case up by the coil. This ground wire is still being used eventho I am now running 40idf's. Good Luck....another commonly overlooked wire is the resistor pack for the injectors on the 1.8 KP |
Lo-Fi Version | Time is now: 24th September 2024 - 01:06 PM |
