Newly Discovered Hell Hole Cancer |
kenshapiro2002 |
Oct 28 2009, 10:43 AM
Senior Member Group: Members Posts: 1,441 Joined: 23-July 09 From: Bawlmer, MD Member No.: 10,598 Region Association: MidAtlantic Region |
Well, the hole itself was repaired, but I was just able to excavate as seen below. Surrounding area is ice pick proof. What are the best "fixes" to be done while keeping the car together? It does not extend into the interior either and the side runners are very solid (had been replaced too).
Attached image(s) |
kenshapiro2002 |
Oct 29 2009, 11:32 AM
Guys...the car is as solid as can be (well...almost). The floor needs some POR15 but you can't drive an ice pick through the floors or longs with a freakin' hammer. It's obvious to me that the PPO, who has written to me, replaced the longs and the hell hole damge in the engine compartment, and never did the triangular corner of the Unibody below the hell hole. It "looked good" to me too until i started poking, so Im sure it was much better when he did the "restoration" in 1989. I'm convinced I just need some patch work on the actual horizontal area shown in my original shot. That being said...please (and I mean it) chime in. |
SirAndy |
Oct 29 2009, 11:52 AM
Resident German Group: Admin Posts: 41,711 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Guys...the car is as solid as can be (well...almost). Just as i thought ... (IMG:style_emoticons/default/icon8.gif) Attached image(s) |
jasons |
Oct 29 2009, 12:12 PM
Jackstand Extraordinaire Group: Members Posts: 2,002 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None |
Yeah, the long should fold the other direction. What I don't get is, I don't see the coincident repairs that usually occur with the repairs that were done. If that inner long was repaired, why does the outer long look OK? I would think if the inner long needed repair that bad, wouldn't the outside long be bad too? |
kenshapiro2002 |
Oct 29 2009, 12:25 PM
I assume they were both done. Anyway...even though you guys wouldnt have done it the way it was done, I don't care about originality and it's way too strong and nice for me to go redoing it for my purposes. I'll keep poking underneath where I showed it was "soft". The car basically sat for 20 years in a garage after the longs and upper hell hole were repaired, so I'm also assuming that whatever wasn't taken care of simply rotted away even though the car was then out of the weather and wasn't getting any more water intrusion from above. I'm also assuming (please correct me) that the entire longs were replaced...inner and outer.
Lo-Fi Version | Time is now: 28th June 2024 - 02:41 PM |
