kenshapiro2002 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,441 Joined: 23-July 09 From: Bawlmer, MD Member No.: 10,598 Region Association: MidAtlantic Region ![]() |
Well, the hole itself was repaired, but I was just able to excavate as seen below. Surrounding area is ice pick proof. What are the best "fixes" to be done while keeping the car together? It does not extend into the interior either and the side runners are very solid (had been replaced too).
Attached image(s) ![]() ![]() |
ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,937 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
Pic 2 looks like there was a repair at the rear of the long, where the black spray-on undercoat is.
Pic 3 shows a questionable repair done to the floor/inner long.It may be strong but certainly isn't faithful to the way the floor and long were originally assembled. The firewall has two layers at the bottom 6". They are roughly one or two inches apart. The floor often rots between the two, from water that gets inside and can't get out. |
kenshapiro2002 |
Probably the "soft" area I showed in my first shot?
Pic 2 looks like there was a repair at the rear of the long, where the black spray-on undercoat is. Pic 3 shows a questionable repair done to the floor/inner long.It may be strong but certainly isn't faithful to the way the floor and long were originally assembled. The firewall has two layers at the bottom 6". They are roughly one or two inches apart. The floor often rots between the two, from water that gets inside and can't get out. |
Lo-Fi Version | Time is now: 28th June 2024 - 02:49 PM |
