missing gears |
missing gears |
svsv |
Oct 17 2009, 08:14 PM
Newbie Group: Members Posts: 8 Joined: 26-September 09 From: NC USA Member No.: 10,851 Region Association: None |
ok here we go 2nd & 4th have dissapeared just replaced ball cup in rear they were there after that and now i can hold it were they should be and feel the syncros grab and pull it in then it is in gear but a normal shift not there at all the shifter is perty sloppy but where have they gone (IMG:style_emoticons/default/confused24.gif)
VaccaRabite |
Oct 18 2009, 06:02 PM
En Garde! Group: Admin Posts: 13,615 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
When you do the firewall bushing, do not be surprised if you find no bushing there at all. I have seen a few 914s now that did not have not there to start with. Funny things happen in 30 years.
Boil the firewall bushing and it is MUCH easier to install. Otherwise you are going to have to make a tool to press it in, which is a PITA (and the route that I took). Zach |
svsv |
Oct 29 2009, 09:00 PM
When you do the firewall bushing, do not be surprised if you find no bushing there at all. I have seen a few 914s now that did not have not there to start with. Funny things happen in 30 years. Boil the firewall bushing and it is MUCH easier to install. Otherwise you are going to have to make a tool to press it in, which is a PITA (and the route that I took). Zach Thankyou for the extra info. I crawled under it and inspected that area, what I found was that the coupler bushings had removed themselves. The firewall bushing is on its way also so it is on the list to. From what I read on that install they can be real bears to get drove in. So all tips and tricks are appreaciated. Thanks again Seth |
Markl |
Oct 29 2009, 10:08 PM
Member Group: Members Posts: 75 Joined: 14-September 09 From: Colorado Member No.: 10,802 Region Association: Rocky Mountains |
When you do the firewall bushing, do not be surprised if you find no bushing there at all. I have seen a few 914s now that did not have not there to start with. Funny things happen in 30 years. Boil the firewall bushing and it is MUCH easier to install. Otherwise you are going to have to make a tool to press it in, which is a PITA (and the route that I took). Zach Thankyou for the extra info. I crawled under it and inspected that area, what I found was that the coupler bushings had removed themselves. The firewall bushing is on its way also so it is on the list to. From what I read on that install they can be real bears to get drove in. So all tips and tricks are appreaciated. Thanks again Seth I just did mine - used a .75x3" bolt, nut, and a couple of fender washers. Bolt through the firewall, go underneath and slide the bushing on, follow with washer and nut. A little lube (soap or glycerin) will help, but it presses in real easy. Didn't even think about boiling it - Zach, is that to kill the rust viruses? |
Lo-Fi Version | Time is now: 21st December 2024 - 11:12 PM |
