> missing gears
svsv
post Oct 17 2009, 08:14 PM
ok here we go 2nd & 4th have dissapeared just replaced ball cup in rear they were there after that and now i can hold it were they should be and feel the syncros grab and pull it in then it is in gear but a normal shift not there at all the shifter is perty sloppy but where have they gone (IMG:style_emoticons/default/confused24.gif)
tat2dphreak
post Oct 29 2009, 10:18 PM
stoya, stoya, stoya
I did the bolt+washers press...
the conversion bushing for a 70-72 -sideshifter conversion seems tougher than the stock one, FWIW.
I agree with zach tho, replace all the bushings and cone screws, and inspect for leaks while you are at it. on my Side shifter the shaft seal was leaking AND the O-Ring, if one is leaking, may as well replace them both.
only holy water and ospho kills rust viruses... on second thought, I'm not catholic... just ospho(or other suitable heavy chemical)
- Lo-Fi Version Time is now: 21st December 2024 - 11:09 PM
