69_Lex |
Member ![]() ![]() Group: Members Posts: 52 Joined: 28-June 08 From: wyoming Member No.: 9,226 Region Association: None ![]() |
Has anyone had any good or bad experiences using Fusor Metal Adhesives? I'm considering using it to bond my outer longs on and the long clamshells on. Then using structural rivets to prevent the unzippering effect of the bonded surfaces.
Pros I've read 1. Metal adhesives shear strength is greater than spot welds or the sheet metal being bonded. 2. Provides corrossion protection on surfaces being bonded (bonded surface) 3. No warping of metals, unlike welding. Cons I've read 1. Bonded surfaces can unzip, which is why a spot weld or rivets ar needed along bonded seam. 2. Don't let it get into areas that you don't want bonded or filled. Any thoughts are appreciated. |
Bartlett 914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest ![]() |
This looks very interesting. You can even weld and glue at the same time! You can glue in the long and then spot weld. Now there is a glue / sealant over the full contact surface. I do not know about rosette welds. But this looks like it would be better than weld through primer. You will also not need seam sealer.
Fusor Metal Bonding |
Lo-Fi Version | Time is now: 27th June 2024 - 11:37 PM |
