Rick Cabell |
Newbie ![]() Group: Members Posts: 1 Joined: 20-June 09 From: Burlington, Vt. Member No.: 10,487 Region Association: None ![]() |
Where is the best place to buy a fuel pump for a 1974 1.8 liter? They don't seem to be that common.
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
Because the available pumps, if indeed they ARE available, are relatively expensive, you might want to consider using the 2 port pump common to the '75-'76 914, '75-'79 VW T1, and '75-'91 VW T2. Minor simplification of the plumbing is required, and you must use the later model fuel filter. This conversion means you have a NEW Bosch pump, not a cheap Chinese knockoff (with a horrifying record of reliability) or the unknown quantity of a rebuilt one, and at well under half the price (possibly as low as a third the price!).
The Cap'n |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,580 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
Because the available pumps, if indeed they ARE available, are relatively expensive, you might want to consider using the 2 port pump common to the '75-'76 914, '75-'79 VW T1, and '75-'91 VW T2. Minor simplification of the plumbing is required, and you must use the later model fuel filter. This conversion means you have a NEW Bosch pump, not a cheap Chinese knockoff (with a horrifying record of reliability) or the unknown quantity of a rebuilt one, and at well under half the price (possibly as low as a third the price!). The Cap'n There is also a German made Peerburg pump that is a replacement for the stock pump. It only has two lines, so you have to take the T fitting out of the plumbing and put a straight piece of hose in, but otherwise it works great. |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:16 PM |
