ahdoman |
It's phonetic...Ah-D-O-Man (Audioman) ![]() ![]() ![]() Group: Members Posts: 667 Joined: 7-November 05 From: Santa Clarita, Ca. Member No.: 5,084 Region Association: Southern California ![]() |
I'm in the process of putting the 2.4 from "the turd" back together. Today I installed the crank pulley. Should both Z1 markings (/6 flywheel & Pulley) line up with the case centerline? When the flywheel Z1 is aligned at the case center the pulley Z1 is not. I don't see how either could be misaligned since the pulley has the pin on the back and the flywheel has the offset 6 bolt pattern. Any ideas?
Flywheel aligned on center... ![]() Pulley not (Z1 marks are the red arrows. Sorry about the blur.)... ![]() |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
As was mentioned earlier, the crankshafts are drilled differently on the 2.4 and 2.7 engines. Same pattern, different clocking. While you're doing the new TDC mark on the flywheel, be sure to stamp in the 30 and 35 degree marks as well, and paint mark 'em. You can see the marks through the hole above the flywheel, making is a LOT easier and safer to time the ignition at 6000 RPM.
The Cap'n |
Lo-Fi Version | Time is now: 24th June 2024 - 11:20 PM |
