bandjoey |
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,929 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region ![]() |
this looks like not enough threads poking through.. What do you think? I tightened the spring retention -looks like a valve- nut down tight. Is something not lined up right or what?
Attached image(s) ![]() |
ME733 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 842 Joined: 25-June 08 From: Atlanta Ga. Member No.: 9,209 Region Association: South East States ![]() |
(IMG:style_emoticons/default/popcorn[1].gif) ....IT appears that the ..."LOCK NUT" has a much taller upper section, with the plastic/teflon enclosed., this would account for some of the threads not being exposed....And the rubber bushing appears to be "Taller" than a O.E.M. part. (it,s possable the nut is not completely tightened.)....the nut is definately not O.E.M. sized , therefore I am assuming the upper bushings, have been replaced also.....for your consideration. (IMG:style_emoticons/default/popcorn[1].gif)
Lo-Fi Version | Time is now: 24th June 2024 - 11:47 PM |
