Bilstein Adjustible Coil-overs, Clarification needed... |
dlestep |
Nov 1 2009, 07:14 PM
I am smilin'... Group: Members Posts: 890 Joined: 15-January 08 From: Sunrise Florida Member No.: 8,573 Region Association: South East States |
Awhile back, I purchased Patrick Motorsports' Adjustible Coil-Over Rear Bilstein Sport shocks.
They include Eibach 8.00 inch (static free length) x 2.50 ID coils. Everything was warm 'm fuzzy until I did a fit check. (Oh, yeah, they didn't come with new bushings or bumper, nor new washers, sleeve or anything). It did have a new nyloc nut ! (whoopee doo)... Question: is the lowest ring groove on the body the stock setting? On the assembly table, if I measure to the center of the shock body, it works out to be approx 5/12 inches. I was going to place the lock ring near the center of the body. For some reason, the numbers are not working out...maybe it's my math, but... there is a huge difference in static free length... I know that the shock is correct F4-B46-0179-HO, and that the shaft will compress into the body, but its' 4.00 inches above the upper perch, with the threaded collar set at its' lowest setting. Any help here would be appreciated...I ran out of Smart Water. Dave |
dlestep |
Nov 2 2009, 06:30 PM
...thanks guys....
now I have a decision to make... nylon tie wraps tender springs...46.00 each tender spring perches...29.00 each two more questions for those guys that have stiffened their cars. I have installed the chassis stiffening kit for the rear suspension, have boxed trailing arms, have installed trailing heim supports from firewall to suspension console, have welded in a roll cage in the cabin interior, running Bilstein Sports on all four corners and running FUCHS 15 x 8s all around. The Eibach spring rate is 180. I am running 911 torsion bars up front and running a 21 or 22 mm swaybar. 1. Would the 22mm be overkill or effectively reduce the oversteer induced by the stiffening of the car. 2. Are there any stress signs showing up after the stiffening process? and Where? tks Dave |
Lo-Fi Version | Time is now: 20th June 2024 - 05:45 AM |
