Window Falls Down, keeps popping off guide |
astronomerdave |
Nov 3 2009, 02:01 PM
Member Group: Members Posts: 69 Joined: 26-January 09 From: Los Angeles, CA Member No.: 9,979 Region Association: Southern California |
My driver's side door window fell down in the door. Removing the panel I saw that it was just the little metal tang popped out of the round plastic piece which rolls in a guide at the bottom of the window. Popped it back in. Fine. Until the next day it popped out again. Like an idiot I did this two more times.
Finally last night I decided to figure out what's wrong. I popped it back in but left the door panel off so I could watch what was causing it to get stuck and pop off. I opened and closed the door, slammed it, revved the motor (to get vibrations), pounded on the door. Rolled the window up, down, fast, slow, part way, all the way, all combinations. I must have spent an hour and operated the window probably 100 times (probably about a month's worth of window action on the road). It worked perfectly. So I buttoned it up. This morning I went for a drive and when I tried to roll up the window it popped out again. (IMG:style_emoticons/default/headbang.gif) What is going on and how do I fix this? Thanks, --Dave |
VaccaRabite |
Nov 3 2009, 02:24 PM
En Garde! Group: Admin Posts: 13,554 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
There are adjustment screws inside the doors. Sounds like it needs to be adjusted, but I am not familiar with how the early regulators work since my car has late ones.
The plastic slide/bushing might need to be replaced too. maybe it is just worn. Zach |
oldschool |
Nov 3 2009, 02:28 PM
Advanced Member Group: Members Posts: 3,372 Joined: 29-October 08 From: P-town Member No.: 9,705 Region Association: Southern California |
underthetire |
Nov 3 2009, 02:30 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
There are adjustment screws inside the doors. Sounds like it needs to be adjusted. Zach Zack what about the stuff that holds the window in place? where can I get that? My 73 had the glue issue. I used gaska-cinch and its been fine. (kinda like rubber cement). |
Lo-Fi Version | Time is now: 28th September 2024 - 07:16 AM |
