HUBBSTER |
Newbie ![]() Group: Members Posts: 26 Joined: 31-October 09 From: Miami, FL Member No.: 10,996 Region Association: South East States ![]() |
I'm thinking of dropping an LS1 or LS3 into a 914
A stock C6 Vette w an LS3 cruises at 85 in 6th at 30 MPG I would imagine that w the same injection and computer the LS3 in a 914 would return considerably better MPG Have any of you LS1 or Scooby conversion guys checked your MPG ? Thanks |
RJMII |
Jim McIntosh ![]() ![]() ![]() ![]() Group: Members Posts: 3,125 Joined: 11-September 07 From: Sandy, Utah Member No.: 8,112 Region Association: None ![]() |
go with a Boxster S 6 spd and the LS_ engine. =o) Then you'll have sixth, and water cooled gear ratios, and that high MPG when you keep your foot out of it.
http://www.kennedyeng.com/vw_por.htm IIRC the 996 is the same as the Boxster S trans. A Cayman engine will bolt to a Boxster S transaxle. |
HUBBSTER |
RJMII |
go with a Boxster S 6 spd and the LS_ engine. =o) Then you'll have sixth, and water cooled gear ratios, and that high MPG when you keep your foot out of it. Sounds good. Do the LS1 and LS3 engines fit pretty much the same ? I have no idea. I've been trying to get an adaptor to run my Mitsubishi turbo V-6 with a Boxster S transmission. I've about got the plumbing figured out to go twin turbo and make it to where I can keep my rear trunk as a trunk. There's a lot of info out there about the 3000GT VR4 upgrades and HP numbers, only the 914 is a third of the weight. |
HUBBSTER |
Lo-Fi Version | Time is now: 24th June 2024 - 07:25 AM |
