Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,684 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
As the volume of parts has grown I have had to centralize my operations onto my website to keep everything straight. It was a nice surprise for a member that wanted a bumper top and found out they weren't $375 any more.
You can find my parts and current pricing listed here- http://shop.914rubber.com/ |
steveherman |
Member ![]() ![]() Group: Members Posts: 380 Joined: 12-September 09 From: Kissimmee Florida Member No.: 10,799 Region Association: South East States ![]() |
pm sent
budman5201 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 595 Joined: 1-April 07 From: tempe, az Member No.: 7,635 ![]() |
does your windshield to dash seal have the steel clamp on the inside so it just clamps around the stock channel or do i have to glue it in??
I am also interested in the one for the back window to engine lid if it has the clamp also.... thanks, CHris |
Mikey914 |
does your windshield to dash seal have the steel clamp on the inside so it just clamps around the stock channel or do i have to glue it in?? I am also interested in the one for the back window to engine lid if it has the clamp also.... thanks, CHris The rear has an aluminum clip so it will not rust. The front is made from Santoprene (better for the high temps in the sun) with a low clearance opening. I could have put the clip in, but it makes it harder to install with the windshield in. This seal is kept in place mainly by the close tollerence on the opening, but I cut mine about 1/8" longer than it needed to be and installed the corners first working my way to the center. This causes it to "over-center" and help hold it into place too. As it's not really a "seal" and a cosmetic piece it work out fine. Mine is also about 1/16" larger than stock making it hide the edge of the vinyl better. Hope this helps. |
Lo-Fi Version | Time is now: 27th June 2024 - 07:11 PM |
